Re: Suzuki DT 85, 1982 electrical
Hi,<br />According to Seloc Suzuki repair manual (1988-1999) there is Suzuki CDI tester and test cord package for testing a CDI unit. A CDI unit can be tested with this equipement when the CDI unit remain installed on the outboard or it can be tested removed from the outboard.<br /><br />According to Clymer Suzuki shop manual (1985-1991) You can perform some tests with a suitable peak reading voltmeter and an ohmmeter. Things like peak voltage output, CDI unit output, charge coil output, pulser coil, counter coil and battery charging coil output should be possible to test with these equipements. The procedure how to do the tests are described in the Clymer manual (but regarding DT85 only for 1988-on, I do not know if the procedure is usable on a 1982 DT85 also).<br /><br />I suggest You visit a Suzuki service center to have Your CDI unit tested. If it is broken maybe You can find a second hand to avoid to buy a brand new CDI unit that is probably rather expensive.<br /><br />I had a Suzuki DT65 (1991) before, great 2-stroke. Never had any problem with the CDI unit on the DT65 I had (but I had other problems...). I use Yamaha F115 now.<br /><br />Good luck!
