Re: Shift shaft replacement 89 130 Yam
hello<br /> well this is how I do them mark a line up the power head adapter along the bolt. then get as close to the top of the adapter as you can and use a 3/8 or 1/2" drill and drill a hole into the adapter and cut the bolt in half. be very careful not to damage the block. you will find your going to break a lot of fasteners. you will also need to buy another powerhead adapter.you have to dissasemle the exhasut housing to do the job. I have a 225 out here now that runs great I just need to cut the adapter and replace the shift shaft. I am lazy<br /> good luck and keep posting
