skeepyjack
- Mar 10, 2004
- 4
I did a compression test on my Suzuki 1988 150SS V6, reading on all 6 cylinders are 80-85PSI. Is that too low? How is about your? Thanks
Huh??<br />I don't understand what you are saying. You say 2 strokes are ready to go once gases start to blowby. This guy has 80psi when new is 100 or better so obviously there is some blowby or leaking gasket or something like that... so are you saying his motor is about to go?<br /><br />BTW - if it was mine, I would do another test and if it yielded the same result, run it for a while and think about rings or pistons next year.two strokes dont run long after comhbustion gases start blasting past the rings. the compression will remain good until that happens and the the failure will be sudden.
