Re: Yamaha 2 or 4 stroke
willbjew123,<br />Comparison Johnson 70 2-stroke that You have:<br /><br />1) A Johnson 70 4-stroke or Suzuki DF70 4-stroke would be the closest You can get in performance to what You have and still not have a to heavy 4-stroke, I would guess.<br /><br />2) Yamaha F75 or F90 4-stroke is even more heavy, so are Mercury F75 and F90 4-stroke.<br />Mercury Optimax 75 and 90 (both DFI 2-strokes) are also to heavy for Your boat in my opinion.<br /><br />3) As for 2-strokes I would check out these:<br />- Yamaha 90 2-stroke (very light)<br />- Mercury 90 Classic 2-stroke (also light)<br /><br />4) If for example CARB 3- or 2-star is important to You and lower fuel consumption regarding 2-stroke I would add also (both not so heavy):<br />- Tohatsu 90 TLDI (CARB 2-star)<br />- Evinrude E-tech 90 (CARB 3-star)<br /><br />Johnson 70 4-stroke or Suzuki DF70 is probably the realistic alternative for 4-strokes in Your case since the other larger 4-strokes mentioned will be heavier.<br />Yamaha 90 2-stroke is very light, probably just a little heavier than your present Johnson 70 hp, so that would be a strong candidate. If You can get a Tohatsu TLDI or Evinrude E-tech serviced near You - maybe consider a 90 hp from them?<br /><br />Good luck!<br /><br />/Bo
