I have a 1986 Suzuki DT-6 2 Cyl and I want to change the water pump impeller.<br />The first step is to remove the shift rod connector which consists of a front<br />section, back section (threaded) and a bolt (All S/Steel). Of course, when I went <br />to lossen the connector.. Snap the bolt was frozen inside and I ended up with 2 pieces.<br />Got the pieces out, and can either drill out the remainder of the bolt and tap a new <br />thread or use a S/S nut and bolt. A new part will take 10 days to order and is quite expensive. My question is.. As the lever only has 3 positions F R and N, when I put the<br />bracket back on, is there anything to look out for ? The manual says it has to be in forward<br />gear for removal and replacement, but I see no reason why it should be. If I manually move<br />the rod into neutral and move the lever into neutral.. I would think it would be the same.<br />Any Suzuki owners come across this ?<br /><br />
