Re: 92 130 idle mixture call for pilot screw 7/8 ths
hello<br /> leave it at 7/8ths<br /> I have found that if everything else is correct the mix screws will be ok at the factory setting. that motor has an idle jet to meter fuel quantity all the screw does is allow more or less of the mixture.leave the mix screws at 7/8ths.<br /> good luck and keep posting
