Re: tilt tube with a nut welded
Those tubes can be a bear to get out. Although I have never seen one with a welded nut on one side. See if it will turn with the welded nut. If so, you are on your way. Best solution I can give is to shoot some lube around the tube and let it sit for 2 or 3 days and try it again. Just don't mushroom it out when you beat on it. If that doesn't work, try heating the tilt tube gently but firmly. working back and forth and then let it cool and try again. Maybe others have better suggestions.
