  #1
Old September 23rd, 2005, 11:21 PM
defcondaze defcondaze is offline
Default what yamaha control box ???
i have a 115 yahama and the only contols i have are for for a 65hp johnson electric shift.model #115ETLKi believe its a 85 , what type of control box do i need to make this work ? is it electric shift also or do i need another cable ? thanks
  #2
Old September 24th, 2005, 12:12 AM
Default Re: what yamaha control box ???
yes i know , do you have anything more specific ..then just yamaha control box
  #3
Old September 24th, 2005, 05:40 AM
rodbolt rodbolt is offline
aqua without anymore info its hard, all control boxes from yamaha can be had with or without the power trim switch. the side mount box with ign harness is a 703 from yamaha and the binnicle is a 704, the 704 does not have the wiriring harness for the engine.. a model number from your 115 is needed. the ign harness on the v4-v6 motors is a 10 pin harness that has not changed since the early 80's. there are some 7 pin harness's that wont work on your application. are you looking for a flush mount,side mount or binnicle mont control ?
  #4
Old September 24th, 2005, 07:43 AM
ill givve you some more info ........... its 2 stroke,V4,2 carbs, it has oil injection on it it has power trim with the button on the engine , the main connector has 10 pins 7 around as a horseshoe and 3 more pins at the bottom of the others, the other 2 connectors 1- 4 pins, and 1- four holes seems like the power tilt has 4 individual single wire connections.in my orig post ... model #115ETLK of engine,looking for a side mount box
  #5
Old September 24th, 2005, 08:05 AM
also mine has pull to choke on back of engine
  #6
Old September 24th, 2005, 08:22 AM
K will make it a 1985 model. for a side mount box you will need a 703 with a harness and power trim switch, a oil harness from engine to oil tank, a alarm harness with round connectors from engine to tach and a trim harness with round connectors from engine to tach, you will also need the harness from the 4 wire pig tail on the 703 to the tach/gauge panal assy. seeing as you dislike giving any information as to control box type thats about all for now. a yamaha rigging manual would be helpful to ya about now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 703 control box downhilldai Yamaha & Suzuki Outboards 4 May 22nd, 2006 03:53 PM
control box for Yamaha 9.9 hastingsml Yamaha & Suzuki Outboards 1 May 10th, 2006 08:54 PM
yamaha 703 control BugTosser Yamaha & Suzuki Outboards 2 March 28th, 2004 05:17 AM
Yamaha control box and OMC yrag Yamaha & Suzuki Outboards 1 July 14th, 2002 09:42 PM
Yamaha 703 Control lesterthedog@go.com Yamaha & Suzuki Outboards 2 May 21st, 2002 05:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
