YAMAHA 55EL choke.
on my YAMAHA 55 EL there seems to be something missing on the choke mechanism, Firstly the choke is electrically opperated by a solenoid ,the two choke butterflies are inter connected by a link, which are activated by the solenoid, but the bottom carburettor choke shaft has a plate (cam shape) with cutout stops for the butterfly shaft movement,this "plate" still has a plastic linkage style clip attached to it but no linkage,I thought that this linkage might connect to the fast idle speed adjustment in some way,When I move this plate manually then the choke works normally, ( the plate is rotated until the butterflies just start to move) but if this plate is moved back to the rest possition then the choke will not opperate normally ,as though the choke butterflies are sticking open, has any body got a drawing of what this linkage arangement should look like and how this part of the choke should function,at the moment it looks as though the butterfly shaft is too far open, what is the correct procedure to set up the choke on this type of motor,Kind regards William Wright
