  #1
Old September 17th, 2005, 11:00 AM
Dave Murray Dave Murray is offline
Default Overheat Buzzer 1994 Yamaha 150
Hi- This is my first post to this board- First I did a search on this subject and read some excellent ideas on similar Yamaha problems. I have a slightly different issue with overheat warning buzzer. This only happens intermitently.Only happens at idle speed.Reverts to normal after two or three minutes- so I can get home OK.So far over two years, have replaced the water pump and both sensors. I don't think the dealer believes this is a problem, but I can't stand not fixing it as I don't trust it anymore. Other than this issue, the engine looks and runs like new. Any technical help would be greatly appreciated. Thanks Dave Murray
  #2
Old September 17th, 2005, 04:46 PM
rodbolt rodbolt is offline
Default Re: Overheat Buzzer 1994 Yamaha 150
search more. I have hundreds of posts on your problem
  #3
Old October 3rd, 2005, 08:29 AM
GeraldBelastock GeraldBelastock is offline
Quote:
Originally posted by rodbolt: search more. I have hundreds of posts on your problem
  #4
Old October 3rd, 2005, 08:43 AM
I too have a Yamaha overheating problem. My engine is a 2000 F115 on a 2000 Cobia 184 fishing boat. Overheating occurs at various times intermittently. Sometimes it happens after a few minutes' trolling, other times after a wide-open throttle run. Sometimes the pee stream (telltale) is fine at engine start, but diminishes and stops after a few minutes. Other times the telltale looks fine at low and moderate speed, but seems to DIMINISH at higher speed. I have checked sensor and thermostat, used compressed air to blow out all water hoses and the fuel/cooling water heat exchanger. One thing I have not yet tried is to apply a strong vacuum cleaner to the inlet screens.You say you have many posts on this subject. Is there a "most common" solution or general pattern for solving the problem you can tell us about?
  #5
Old October 3rd, 2005, 06:57 PM
have ya tried a careful cleaning of the pressure valve grommet pocket and install a new grommet. also was the rubber dam under the pump wear plate removed and cleaned. both will cause your symptoms. and has the powerhead been replaced with a reman unit?have the t-stats been replaced lately ?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 Yamaha SWS 250 Overheat at Idle dteufle Yamaha & Suzuki Outboards 3 May 24th, 2005 03:01 PM
Yamaha 60 - buzzer - smoke - overheat? dunchumphrey Yamaha & Suzuki Outboards 11 April 25th, 2005 04:53 AM
95 yamaha 70etlf overheat buzzer tzmach1 Yamaha & Suzuki Outboards 1 July 14th, 2004 03:07 AM
Engine Overheat buzzer TopNotch Johnson & Evinrude Outboards 41 June 24th, 2004 07:02 AM
87 50 hp Force overheat buzzer John5421 Force & Chrysler Outboards 0 July 17th, 2003 08:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
