  #1
Old September 12th, 2005, 02:44 PM
radard radard is offline
Default Yamaha 200 EFI fuel pump
I have a 2000 Yamaha 200 EFI. The engine consistently cuts off after a minute or two at high rpm. Runs perfect at low rpm and idle. New fuel pump was recommended. Would like opinion prior to purchasing the expensive part.
  #2
Old September 12th, 2005, 03:37 PM
rodbolt rodbolt is offline
Default Re: Yamaha 200 EFI fuel pump
I would clean the VST pump filter first or maybe do just a wee bit o testing in accordance with the service manual on fuel system vacum. that pump is about 700 dollars. usually its a work or not work device. usually its a fuel restriction. when was the last service of the VST pump?
  #3
Old September 12th, 2005, 10:16 PM
bigbrownbuku bigbrownbuku is offline
Master Chief Petty Officer
check to see if your delivery pumps have clear diaphragms. if yes change them. if they havent been serviced in the last 2 years change them anyway. had the exact problem on an sx200txry this summer, fuel pressure would be solid for about 90 seconds at wot then jump 5 to 30psi and rpm would fall right off. basically the vst was running out of gas from a ruptured diaphragm in 1 low pressure pump (would run all day at 4000rpm). i changed all the pumps (cheaper to change then rekit) and the high pressure pump because i didnt trust it after it had run outta gas numerous times.
  #4
Old September 13th, 2005, 06:28 AM
Thank you. Could you ID the VST pump for me.
  #5
Old September 13th, 2005, 08:20 AM
front of the engine port side. http://www.yamaha-motor.com/outboard/parts/home.aspx
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
130 Hp yamaha fuel pump tman592 Yamaha & Suzuki Outboards 1 June 30th, 2006 09:56 AM
Yamaha 225 hp OX 66 $1000 Fuel Pump Fix wi1p Yamaha & Suzuki Outboards 22 December 8th, 2005 05:14 PM
Yamaha fuel pump hose clamps swist Yamaha & Suzuki Outboards 1 July 24th, 2004 10:03 PM
Life of Fuel Pump, 90 hp Yamaha foxden Yamaha & Suzuki Outboards 1 July 14th, 2004 09:42 AM
90 hp Yamaha Fuel Pump foxden Yamaha & Suzuki Outboards 2 June 28th, 2004 01:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
