Rodbolt, where is the pump driveshaft in the oil pump on the 98 yamaha 90 hp. I see there is a driveshaft in the engine that is turned by the crank and a round wheel with gears in the oil pump. Which one do I remove so I can premix? There is also a tiny piece in the center of that round gear with teeth that is turned by the piece in the block connected to the crank.
