  #1
Old March 30th, 2006, 08:45 AM
mansueto mansueto is offline
Default Sandblasting paint from aluminum - HELP
My aluminum runabout has 1 coat of paint over the entire hull that someone rolled on years ago. The deck/hood is covered with a slightly tougher coating called DuraDeck...which the DuraTech company put on there 40 years ago. It's a bit tougher than paint, more like a very thin plastic texture finish. Which blast material should I be using with a 2200 psi power sprayer to get the paint and coating off? THANK YOU in advance.DJman
  #2
Old March 30th, 2006, 09:43 AM
LubeDude's Avatar
LubeDude LubeDude is offline
Default Re: Sandblasting paint from aluminum - HELP
Sand blasting aluminum is not a very good Idea, it will make the aluminum "VERY" rough and can actually deform it! I vote, DONT DO IT!!!!!!
  #3
Old March 30th, 2006, 09:48 AM
tommays's Avatar
tommays tommays is offline
DOUBLE NO there should be a stripper that will remove ittommays
__________________
If a dirty bottom slows you down what do think it does to your BOAT
Tommays
  #4
Old March 30th, 2006, 11:50 AM
noelm noelm is offline
there are lots of alloy strippers around, but it can be blasted but only by people who have a record of alloy blasting as it is tricky and indeed "normal" blasting can deform and even "blast" right through the metal
  #5
Old March 30th, 2006, 12:02 PM
Dead Eye Dead Eye is offline
Hope you like worms, 'cause I think you'll open a big alum. can of them. I'd try a stripper (I lean more towards red heads) or find a good color and repaint it. Dead Eye
  #6
Old March 30th, 2006, 02:46 PM
I have used a stripper that was used in the aircraft industry and it worked a treat, but I also had a big aluminium boat blasted and they used some sort of smooth black kinda beads that sort of felt like plastic, did no damage at all and the boat was etch primed by the same people straight away to prevent any impurities and the paint is still good today some 10 years later.
  #7
Old March 30th, 2006, 02:47 PM
Oh and Dead Eye the stripper was not a redhead!
  #8
Old March 30th, 2006, 03:02 PM
brownies brownies is offline
Walnut shell or plastic media for blasting. It will sure make one wavy though. No matter who does it, the metal will be wavy when finished. I'd strip it with chemicals first, second, and third. Then, you might consider having just the seams, crooks, and crannies, lightly blasted just to clean those areas up (if there are any).
  #9
Old March 30th, 2006, 03:19 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
My thought on painting an Aluminum boat,......If the Paint is There,+ Still Well Struck,.......Try applying alittle bit of the New Paint on Top of the existing Paint.......If there's No Reactions,.... Bubbling,... Orange Peel,.... Lifting,.....Leave it There.............Sand it Smooth,+ Prime,& Paint it.............. It saves the Unnecessary Step of treating the Bare base metal,.........Muchless,..... Stripping the Old Paint................................
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #10
Old March 30th, 2006, 03:55 PM
Texasmark's Avatar
Texasmark Texasmark is offline
My '65 Starcraft 18' Holiday I/O complete restoration included hull stripping/painting.I had an empty hull (deck and stringers only thing in it) and took it to a sandblast place in Dallas. They hooked into the bow eye and stern eyes and rolled it into their sandblast area where they had a commercial unit; probably the 2200# you are talking about.The guy did say that he had to be careful as the blaster would overheat the alum and as mentioned deform it.They did a beautiful job for peanuts, then, while it was still hanging they rolled it outside and sprayed a 2 part epoxy white paint on it. It was a beautiful job and the boat was used for 15 years after that that I know of and zero finish problems.Buttttttt these guys knew what they were doing.Mark
  #11
Old March 30th, 2006, 04:11 PM
Texasmark I had the same experience but still stripper is a safe (but harder) way to go if no specialty alloy blasters are in the area.
  #12
Old March 30th, 2006, 07:04 PM
Moody Blue Moody Blue is offline
Fully agree NOT to try sandblasting it yourself. You won't like the result and you may possibly destroy the hull. I've had stainless sheet beadblasted (glass bead, not sand) and it twisted and deformed beyond belief. By blasting the opposite face it straightened out mostly but was still not straight. I can only imagine that alum would be more susceptible.
  #13
Old March 31st, 2006, 09:53 AM
Guys, I really appreciate all of these careful words of advice. My brother is not such a novice as I; this is my first boat, and a big restore job at that. But your words of experience are much appreciated very much!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
paint aluminum hull drewmitch44 Boat Restoration and Building 1 December 18th, 2006 11:31 PM
aluminum paint RyBisp Boat Restoration and Building 4 October 3rd, 2006 08:25 AM
aluminum plate paint JOHNSON110 Boat Topics and Questions (not engine topics) 1 May 25th, 2005 02:57 PM
What best paint and primer to paint an aluminum out drive John Smith Boat Restoration and Building 3 January 22nd, 2003 04:51 PM
Paint aluminum michaelsen Boat Topics and Questions (not engine topics) 6 March 3rd, 2002 06:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
