  #1
Old March 18th, 2006, 06:17 AM
Bob Bismal Bob Bismal is offline
Default Replace my transom in aluminum boat?
I have a 18' 1978 starcraft aluminum v hull with an 1978 115hp Johnson. I've never owned a boat before so I wasn't really sure what to look for when I was buying. I did have a couple Buddy's who I thought knew alot about boats look it over first (all said it wasn't that bad). Anyways I took the boat into the shop to have the motor looked at. The motor checked out great but the hoses are old and need to be replaced. Then they looked at the transom and said they wouldn't do any work on the motor until I had the transom replaced because they were afraid it would break. They told me I shouldn't take the boat out until I get that done either. They don't do that kind of work there, so they weren't trying to sell me anything. Any tips for replacing a transom in an aluminum boat? The guys at the shop said I could get away with pressure treated wood instead of marine grade plywood sense that's what Starcraft probably put in there in the first place 30 years ago. Do I need to put anything on the plywood, doesn't look like there is anything but paint on it now. No kind of fiberglass or hard coating, just paint. Any help?
  #2
Old March 18th, 2006, 08:02 AM
Default Re: Replace my transom in aluminum boat?
Oh yea, anything I should know/watch out for when disconnecting the gas, steering and trim adjusting lines and cables?
  #3
Old March 19th, 2006, 01:34 PM
Rick K Rick K is offline
Bob, it's pretty straight forward. Do a search in here for replacing transom, rotted transom, etc., and you'll get all the info you need, and more. For the debate on marine ply vs. pressure treated, a search here will bring up tons of info too.It's been said that the new pressure treated lumber will react negatively with aluminum. I'd go with marine ply, epoxied together, etc. Trust me - everything you need to know is in here. Good luckRick
  #4
Old March 19th, 2006, 02:41 PM
Capn Kirk Capn Kirk is offline
I replaced my transom "79 starcraft holiday".Was real easy once motor is off.I took off top trim,went inside unscrewed many screws that attatch alum.motor well area to plywood transom from inside.Then got a large screw eye and screwed it into the end grain of top of plywood.Then I hooked a chain from the hook to a large pipe[like 2 1/2"]set one end of the pipe on the boat and with longer length in hand I pryed the plywood out.It came out in one piece.When I replaced it I used a dry treated plywood.I didnt even realize they made dry and wet treated till I did this.I believe it took two 3/4" pieces.And dont piece it,use full pieces.Also didnt coat it with anything,worked great!Make sure you put all screws back in,thats where most of the strength is.Hope it helps
  #5
Old March 20th, 2006, 10:32 AM
Quote:
Originally posted by Coastie Dad: I replaced my transom "79 starcraft holiday".Was real easy once motor is off.I took off top trim,went inside unscrewed many screws that attatch alum.motor well area to plywood transom from inside.Then got a large screw eye and screwed it into the end grain of top of plywood.Then I hooked a chain from the hook to a large pipe[like 2 1/2"]set one end of the pipe on the boat and with longer length in hand I pryed the plywood out.It came out in one piece.When I replaced it I used a dry treated plywood.I didnt even realize they made dry and wet treated till I did this.I believe it took two 3/4" pieces.And dont piece it,use full pieces.Also didnt coat it with anything,worked great!Make sure you put all screws back in,thats where most of the strength is.Hope it helps
What store did you get the dry treated plywood from?
  #6
Old March 20th, 2006, 04:21 PM
Most lumber co should carry it,but I bought mine from wolohan lumber.
  #7
Old March 21st, 2006, 09:26 AM
Thanks, I called Wolohan lumber in Ludington. Turns out their closing in ten days. The guy did tell me that they don't have any 3/4 dry treated plywood left, but it's just kiln dried pressured treated and that all pressure treated plywood is kiln dried. What did you use to glue that two pieces together?
  #8
Old March 21st, 2006, 05:11 PM
You can use whats called 3M 5200.It comes in a caulk tube and it is awsome.It takes several days to dry but is forever!You can probably find it in a lot places[hardware stores etc.]but I know West Marine has it. Capt Kirk out----
  #9
Old March 21st, 2006, 06:05 PM
Texasmark's Avatar
Texasmark Texasmark is offline
I did mine too 18' Holiday I/O and it was easy. I had to go to a wood specialty dealer to get the marine plywood. I either found 1.5" or marine glued 2 ea 3/4" pieces together. Don't remember. Was not treated wood but I did put linseed oil on it real good before installing and then painted it.Course mine was a full blown restoration so it was easy because i had gutted the boat floor and all.Mark
  #10
Old March 22nd, 2006, 02:49 AM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
What, where, how is dry treated ply? Is that the pre-dryed pt stuff?Bill
  #11
Old March 22nd, 2006, 09:29 AM
From what I've read at different plywood manufacturer sites and what I got from the guy at Wolohan lumber is that all pressure treated plywood is dried to at least 18% moisture (or dry plywood).Some info on marine plywood. Looks like marine grade plywood is not treated for rot. http://www.glen-l.com/wood-plywood/marine-plywood.html
  #12
Old March 22nd, 2006, 02:00 PM
Texasmark's Avatar
Bob B. What did you use......?I can remember a purple marine glue that we used in the '50's that would glue 2 pieces of oak together so good that if you split it after curing it would rip the oak out by the grain.On replacing a transom, you are talking about a 30 year old boat. If you replace it and it survives 30 more years do you think that the rest of the boat will be up to another replacement? I doubt it.Next. Most transoms are bolted in place so the bolts hold it together; glue is not a real contributing factor as I can see it.So where does that leave us?Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum Boat Transom Modification. pnut Boat Restoration and Building 4 July 9th, 2006 11:58 AM
Aluminum boat transom replacement San Antonio Cop Boat Restoration and Building 2 December 8th, 2005 05:53 AM
Aluminum Boat Transom Rebuild cclaeys Boat Restoration and Building 4 August 17th, 2004 08:19 PM
Transom in Aluminum Boat Question Bass Runner Boat Restoration and Building 7 May 19th, 2004 02:22 PM
wood transom on aluminum boat nigelbear Boat Restoration and Building 6 February 13th, 2004 08:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
