Prop shafts?
Barnacle_Bill
Are the prop shafts on a 1983 Merc 150 and a 1996 Merc 150 the same? Another words, are the props interchangeable?
Chris1956
Re: Prop shafts?
Why not look them up in a Propeller application table to see if they interchange. It appears to me that they do. The '83 is a V-6?
walleyehed
Re: Prop shafts?
"Most" all V6 and V8 outboards will be 15 spline of the same size. we swap props from all manufacturers all the time...a different thrust washer or aft washer may be required but they will work.
