  #1
Old August 22nd, 2005, 11:34 AM
Bahama Dawg Bahama Dawg is offline
Default oil leak from Yamaha 115 HP 4 stroke
I have twin 115's, and the right motor (F115TXRZ) Manuf. 11/2000 periodically leaks oil into the transom area of my Cobia 254CC. It does not do it all the time. It is noticeable when I return to the dock, tilt the motors out of the water, then when I return the next day a small amount of oil has leaked. It appears to be dripping off the brackets that hold the motor on the transom. It furhter appears to be coming onto the brackets from the base of the motor section housed inside the removeable cowling. I check the engine oil level every day, and it does not appear to be decreasing. What is causing the leak?
  #2
Old August 22nd, 2005, 02:48 PM
jk1162 jk1162 is offline
Default Re: oil leak from Yamaha 115 HP 4 stroke
It isn't a hydraulic steering hose leak is it.
  #3
Old August 22nd, 2005, 05:04 PM
clanton clanton is offline
There is a replacement oil pump for some of these engines, to stop the oil leak. Dealer should have service bulletin with year and serial number of the engines needing this pump replace.
  #4
Old August 22nd, 2005, 05:55 PM
rodbolt rodbolt is offline
what clanton says. there is a problem with a few . check with your dealer.
  #5
Old August 28th, 2005, 10:31 AM
Quote:
Originally posted by clanton: There is a replacement oil pump for some of these engines, to stop the oil leak. Dealer should have service bulletin with year and serial number of the engines needing this pump replace.
  #6
Old August 28th, 2005, 10:32 AM
Thank you for the info. I will check with a dealer reference the replacement oil pump.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
40 HP Yamaha 4 Stroke - Fuel Leak rutropa Yamaha & Suzuki Outboards 0 July 19th, 2006 11:26 PM
Yamaha 100 four stroke engine oil leak while tilted! kkilloy Yamaha & Suzuki Outboards 8 November 2nd, 2004 05:13 AM
2003 Yamaha 115 four stroke oil leak zuru Yamaha & Suzuki Outboards 5 November 5th, 2003 04:52 PM
Fuel leak 50 H.P. Yamaha 4 stroke Makky Honda & Tohatsu/Nissan Outboards 3 October 23rd, 2003 08:51 AM
Oil Leak '99 Yamaha 9.9 hp 4-stroke gherrx Yamaha & Suzuki Outboards 1 June 29th, 2003 12:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
