  #1
Old August 20th, 2005, 07:12 AM
Mudd_catt Mudd_catt is offline
Default 200 hp Yamaha Charging
I recently purchased a 19 1/5 ft Stratos with an '88 model 200 HP Yamaha. The problem I have with this motor is that the charging system doesn't seem to be very stout, especially while running the headlights on the boat at night. I had to be jumped off the other morning, and even after I ran 8 or 9 miles at wide open, after I killed the motor, it barely had enough juice to lower the motor on the trailer. The model # on the motor is 200 ETLG. Also, I can't seem to get this boat above 61 oe 62 at wide open at 5300 rpm, running a jack plate and stainless prop.
  #2
Old August 20th, 2005, 08:21 AM
bossee bossee is offline
Default Re: 200 hp Yamaha Charging
Hi,Are You sure your battery is healthy? All cells OK? Fully charged? (charge it to make sure it is fully charged)Battery connections OK?Battery charging components: Flywheel permanent magnets, stator, voltage regulator/ rectifier and battery. Rotating flywheel magnets induce an alternating current (AC) in the stator coils. AC current is rectified to direct current (DC) by the voltage regulator. DC output from the voltage regulator is used to charge the battery. The voltage regulators sense the battery voltage as a measure of the batteryÂ’s state of charge and regulate the DC current flow to the battery. The voltage regulator(s) usually protected by fuse(s).General Troubleshooting:A fault in the battery charging system will usually cause the battery to become UNDERCHARGED.A defective voltage regulator or a stator winding shorted to ground may also allow the system to OVERCHARGE the battery.If a problem exists in the charging system, visually check the following:Check for loose or corroded battery terminals.Check condition of the battery.Visually inspect all wiring between stator and battery for cuts, chafing and disconnected,loose or corroded connections.Excessive electrical load (from too many accessories) will cause battery to run down,even if the system is operating correctly.If the battery is undercharged, proceed with regulator, stator, and rectifier tests.Above from a Mercury Service Manual, but since it is general info if will apply to a Yamaha also.Here I hope somone else will help You since I do not have a Service manual for the Yamaha outboard You have and can not tell You how to test the regulator, stator, and rectifier (that I assume is described in the Service Manual like it is for Mercury).You may get valuable info also if you search this Yamaha & Suzuki forum with the word chargingGood luck.
  #3
Old August 20th, 2005, 12:26 PM
I have checked the batteries, they seem good according to the test equipement. This is the second time since I bought the boat that I have had issues with the charging system. The first was when my two-year old got into the drivers seat at the house, and left the master power switch on. That time, we fished a three hour tourney, and had to jump from the trolling battery every time we cranked. I am starting to think from all the checking today, that it just does not have a very stout charging system, hence the headlights are about to go off the boat.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 55 el charging rate. jurgenscraft Electrics, Electronics and Trolling Motors 3 August 7th, 2005 07:17 AM
Yamaha 225 Not Charging fishsniffer Yamaha & Suzuki Outboards 10 May 26th, 2005 09:43 AM
aux. charging lead on yamaha knotyet Yamaha & Suzuki Outboards 7 March 17th, 2005 06:30 PM
yamaha 8hp charging output cherpuss Yamaha & Suzuki Outboards 0 January 15th, 2004 09:05 AM
30 yamaha not charging boc Yamaha & Suzuki Outboards 0 May 4th, 2002 12:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
