Hey gang. Any ideas on this ?
I just got this boat, ran great last week, I put gas in it today, pre-mix, but I used the Pennzoil Synthetic, I could no get to the dealer to buy Yamalube last week.
Anyway, to the symptoms, running along fine, then the motor just bogs, I back off the throttle, and it wants to stall, wait a few seconds, then it picks up power again, runs fine for a couple minutes, then does it again, sometims stalls , sometimes it doesn't, but it just falls on it's face, over and over, when it does stall, it take a long time to get it to fire again. At one point it ran great for 5-10 minutes, other times, 30 seconds.
I get it home, and it fires right up, and revs fine, pull the plugs and they look a little wet. Not sure if they should or not, the plugs are new, only ran them once before, last Wed. and it ran perfect all day.
Ok, so, any ideas, maybe carbs flooding the plugs ? ( I know they were cleaned a couple years ago, not sure exactly when ) , maybe it's bad gas ? doesn't like the oil ?
It's odd because it runs perfect for a few, then just dies out, and then will run great again in a few seconds.
It almost feels like it's flooding and drowning the plugs, then once it burns the fuel off, it will get up and run again.
thanks much for any ideas you could provide.
