1985 DT-115 SUZUKI OIL INJECTION REMOVED
jessiewigg
The oil injection on my motor was removed and I run mixed gas in the tank. Been working good for about a year now. I read in another post about changing the jets in the carbs if removing the oil injection on another brand of motor. Would the same be true on my Suzuki? What would the proper size jet be? I live in NC. Thanks for all of your help in the past.
suzuki115
Re: 1985 DT-115 SUZUKI OIL INJECTION REMOVED
I run a '88 Suzi DT115. Removed oil injection when I bought it in '01. So far (knock on wood) it has run excellent for 2nd season. It is mostly run at WOT since I run a kicker or trolling motor otherwise. I did some research on this prior to pulling the oil injection(mostly from this forum), but I did not run accross the jetting issue.
