1985 Yamaha 115 oil injection unit
maximus787
Thanks for the fine reading.. First, when I first got the boat, the red warning light was on. So i found an oil leak on the line going to the small tank on the engine. When I turned the key on after the line was replaced it pumped for a few seconds then blew the top off the tank. I then went to the key and turned it off. Now, the green light barely glows and then blows a fuse under the console. Also the buzzer will not come on. Can the entire pump, gauge assembly be replaced separate?Can I bypass that whole system easily? Thanks for your help. :p
ZmOz
Re: 1985 Yamaha 115 oil injection unit
Just disconnect the whole system and mix the oil yourself. How hard is it to pour some oil in your gas? :) That way you know it's mixed and nothing is wrong.
JB
Moving to Yammy Troubles
