Re: Yamaha 4.3 yems flow sensor
The water pressure sensor is located in the power steering oil cooler. The cooler is located on the starboard front of the engine way down at the bottom. So actually you have three sensors. One is for the temp gauge, high temp alarm and water flow alarm. Uh, you have checked to be sure the flow is enough to trigger the flow sensor. Just because you have water coming out the exhaust doesn't mean you have enough water. Yamaha has none in stock and cannot be ordered from Japan. I've probably got some in the used parts bin upstairs if you need one.
