  #1
Old July 25th, 2005, 01:51 PM
parrothead001 parrothead001 is offline
Default 225 Yamaha idling hot
One of my 1997 225's gives indication that it is overheating at idle. On speed I have no problems. New water pumps, thermostats, good telltale. Only after idling for about 3-5 minutes will the buzzer sound.
  #2
Old July 25th, 2005, 04:21 PM
rodbolt rodbolt is offline
Default Re: 225 Yamaha idling hot
check the pressure relief grommet. replace the grommet and clean the pocket. another problem is if the water pump was replaced and the rubber dam and holder was not cleaned.
  #3
Old July 25th, 2005, 06:01 PM
John from Madison CT John from Madison CT is offline
Your problem is probably your Poppit Valve. (aka Pressure relief valve). It's an easy fix to clean her up. Clean the pocket as Rodbolt notes above. This is the area underneath the grommet.John
  #4
Old July 25th, 2005, 06:07 PM
Thanks for the input. When I pulled the poppit out, should the longer end be installed in the motor or the shorter end? Thanks in advance
  #5
Old July 25th, 2005, 08:09 PM
the tapered side of the valve goes in first. cant remember if its on the long or short side. look at the valve disc and you will see one side has a taper.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Idling blackcatrain Johnson & Evinrude Outboards 2 June 27th, 2005 05:55 AM
Yamaha 75 HP poor idling - timing issue? slazerow Yamaha & Suzuki Outboards 0 July 10th, 2004 07:14 PM
1989 Yamaha 150 Pro-V Idling problem 302w Yamaha & Suzuki Outboards 0 August 4th, 2003 12:07 AM
Yamaha Engine Stalls While Idling sarnajo Yamaha & Suzuki Outboards 3 July 15th, 2003 05:50 PM
Yamaha 200 overheats when idling ssamaniego@msn.com Yamaha & Suzuki Outboards 2 July 19th, 2002 12:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
