  #1
Old July 22nd, 2005, 11:59 AM
goof01698 goof01698 is offline
Default Yamaha 55 fuel flow problem
Hi there, I have been having trouble with my 55hp yammy.I cant get it to tick over properly. I thought it was the fuel pump so I changed the diaghrams but no luck. I changed the fuel tank and line with no difference. When I disconnect the fuel line from the carbs and pump the bulb, I get a good flow of fuel but when I turn the engine over it just spurts a while and then no flow. Any help greatly appreciated.
  #2
Old July 22nd, 2005, 12:04 PM
Default Re: Yamaha 55 fuel flow problem
I suspect the bottom cylinder is not firing as the engine sounds a bit rough and when I took the plug out it was soaking wet. Dont know if this helps figure out whats wrong
  #3
Old July 22nd, 2005, 01:26 PM
Silvertip Silvertip is offline
A plug that is soaking wet on a rough running engine says you are lacking spark on that cylinder. Check for spark.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 225 Excel fuel Flow ( Help needed!) Bandaid Yamaha & Suzuki Outboards 6 February 5th, 2006 02:41 PM
Possible fuel flow problem Paulrusso Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 September 22nd, 2005 09:59 AM
fuel flow restriction problem firehntr92 Johnson & Evinrude Outboards 4 July 21st, 2003 07:01 PM
1989 Johnson 70 vro fuel flow problem Kingbee13 Johnson & Evinrude Outboards 0 June 4th, 2003 03:04 PM
84' Force 15 fuel flow problem? heloman Force & Chrysler Outboards 1 September 23rd, 2002 09:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
