  #1
Old July 18th, 2005, 02:54 PM
Birdup Birdup is offline
Default Yamaha 30 hp lose of third cylinder
THis is all on a 1986 30hp Yamaha oil injected 30ELJHere is what happened. I was out on a windy day and the boat ran fine and planed out all day. Then when I went to head back, against the wind, it would not plane out because the wind was pushing the boat and the bimini top way up causing the motor to run WOT but not on plane. It ran this way for about 20 min then I was able to turn sideways against the wind and get up on plane. After about 5 min on plane it had a power lose and the heat light temp/idiot light came on and it ran really rough. I idled it to the shore and took a look. The oil level was a little low but it was a long way from out. The fuel tank had about 1 gal left in a 6 gal tank. I pulled the plugs and the bottom cyclinder had a wet plug. I figured the plug was fowled from lugging the engine. I cleaned the plug and it got up on plane fine for about 30 seconds then it did the same thing. I idled it back to the dock and brought it home. It ran smooth at low rmps. The motor was borrowed so I need to fix whatever is wrong before I return it. So do you think it is a fowled plug? What should I check. I have a lot of OB experience just non with Yamahas. P.S. I'm buying a 89 30hp so any help here will help me in the future.
  #2
Old July 19th, 2005, 03:16 PM
Default Re: Yamaha 30 hp lose of third cylinder
Wow no help yet?Well I'm replacing the fuel pump assembly as well as all the hoses and new plugs. It is a 87 30hp SH
  #3
Old July 19th, 2005, 04:06 PM
skidplate skidplate is offline
replace all plugs w/ new ngk and try again . This is a cheap fix
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 50hp lose of power after 10 minutes Julian Smart Yamaha & Suzuki Outboards 4 January 16th, 2007 03:12 PM
Yamaha 89, 90hp, Lose power malain123 Yamaha & Suzuki Outboards 1 September 6th, 2006 08:13 AM
Yamaha 70 lost cylinder scotchguy Yamaha & Suzuki Outboards 1 March 31st, 2006 03:39 AM
Getting water in one cylinder, 200 HP Yamaha milljo Yamaha & Suzuki Outboards 5 November 9th, 2004 01:42 AM
1986 Yamaha 115 lose of water pressure Pete Singleton Yamaha & Suzuki Outboards 2 December 7th, 2003 02:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
