  #1
Old July 15th, 2005, 09:06 AM
96century 96century is offline
Default Yamaha 175 S/W oil injection pump adj.
1996 Yamaha S175hp salt water series Mod# TXRU6G5 UL S/N 500427.My factory manual calls for oil pump adjustment to be all the way to the stop (touching it as I interpret) is that correct? it has about .035 to .040 gap on it now. The problem I believe stems from slow trolling bumping in in and out 1 to 2 kts (its King season here) I use ring free @ the 1% ratio on every tank. On my last trip out I lost lots of power, found 1 fouled plug. Replaced plugs with OEM spec plugs gapped IAW (In accordance with)specs, same as I took out. The big question is should I adjust the oil pump linkage as the book says to "0.OO" ? or should I leave a .02 to .05 setting. Will it still get oil fully closed? does it have a built in bleed amount? or is my publication in error?
  #2
Old July 15th, 2005, 04:59 PM
rodbolt rodbolt is offline
Default Re: Yamaha 175 S/W oil injection pump adj.
if your going to adjust it remember its with the throttle plate fully closed. that means not on the idle screw. the fastest way is to dissconect the carb shutter link from the bottom carb to insure its fully closed. I usually shoot for about .005 to .010" between the arm and the stopper. also check your plug caps and recirc valves.
  #3
Old July 15th, 2005, 05:40 PM
Thanks Rodbolt, I'll check it first thing in the morning. What are the recirc valves?
  #4
Old July 15th, 2005, 06:06 PM
they are the nipple looking things in the block. they are not easy to access and the manual never mentions them. but they are one way check valves. test them with a syringe and some alcohol. if you can suck and blow through them they are bad and can cause plug fouling and idle issues. fouled plugs are strictly a symptom never a cause.
  #5
Old July 15th, 2005, 07:36 PM
Ok, Thanks again, I'll post what I find.
  #6
Old July 16th, 2005, 07:46 AM
Ok, I found the recirc valvles I think, are they the ones on the side of each cylinder on the block which also have a dual nipple at the bottom of each carb? To test them with a syringe & alcohol, do you reccomend any particular point, ie at the base of each carb or individually? also where & what kind of hosing connects them all is it special? or automotive type? When I test them am I supposed to try& push alcohol thru them or pull air thru them? If I find a bad one how do I get it out are they pressure fitted or threaded are they easily found at yamaha shops or is an order item? Do they port directly into the lower section of the cylinder area or some where else?Thanks for your help Rodbolt you helped me in the past with my trim sensor, I now pay special attention to it after each use to flush it extra special & to lube it with wd40 every other.El Dorado
  #7
Old July 16th, 2005, 08:21 AM
Rodbolt, I found on other earlier posts about the recirc valves from that I now know that they port into the intake port & that they are pressed in.How should I remove one without destroying it flush? I also read on how to test just try to flush some alcohol thru it!! would mixed fuel be better or will the alcohol just evaporate? also where & what kind of hosing connects them all is it special? or automotive type? I do have red capped spark plug covers, so if they're resistor type is the BR type NGK plug a resistor plug?Thanks
  #8
Old July 16th, 2005, 06:19 PM
Well I checked all 6 recirc valves, they passed me injecting alcohol into them & before the syringe was empty I would attempt to suck it back, all I got was a vaccum so am assuming the check valve portion is working as advertised!! I adjusted the mikuni oil injection pump to about .008 I'm estimating, because .005 would go in but .010 would'nt. I'm glad the recirc valves were ok as I saw on one of your past posts that they run at the tune of $26.00 each, ouch. So in conclusion I believe my oil injecrion pump was a bit rich, I'll check the plugs after my next fishin trip, hopefully wednesday, when the King Fish tournament guys are supposed to take a day off. Please tell me if you think I need to check anything else for the fouling plug symtom, or is it likely the slow trolling, bumping in in out combined with the rich setting the oil pump had was the cause of fouling a couple of plugs? Thanks, again Rodbolt, you are an intregal part of this forum, with out your expertise, it woudld't be the same. Thanks.
  #9
Old July 17th, 2005, 04:49 AM
could vave been an oil link adjustment. glad the ricic valves all tested good. good luck with the fishing
  #10
Old July 17th, 2005, 02:38 PM
Thanks, again, to you & this forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 90 HP yamaha oil injection pump test klarest Yamaha & Suzuki Outboards 2 September 26th, 2005 03:31 PM
Alarm? Without the oil injection pump... KCLOST Mercury & Mariner Outboards 1 October 15th, 2003 01:54 PM
Oil injection pump smoker craft dave Non-Repair Outboard Discussions 3 June 7th, 2003 02:19 PM
Don't want oil injection can I leave the pump dakk1 Mercury & Mariner Outboards 2 June 2nd, 2003 08:25 AM
Oil injection pump failure? dterwill Mercury & Mariner Outboards 8 October 1st, 2002 03:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
