I have a 2000 model year Yamaha 9.9 long shaft Hi-thrust with a 701 remote control. The motor has seen very little use but its gear shift cable abitrarily makes the neutral or reverse position the actual neutral position; this means I never know where the lever needs to be to start and often means I have no reverse at all. In addition, the throttle cable has limited range when in forward. Lately, I've discovered they interact for starting as I cannot get the engine to fire at all, at times. I've opened the linkage box just outside the front of the engine's hood/cowling and can see both cables need realignment. How do I identify the right position for each cable, get the cables back into the right position, make them stay in the correct position, etc. I'd really appreciate a diagram if you know where I might find one. If it shows the correct way to reinstall the plastic retaining clip, even better!
