  #1
Old July 9th, 2005, 03:03 PM
mrjwilson mrjwilson is offline
Default yamaha 2000 f115 4 stroke dies at high rpm
yamaha 2000 f115 4 stroke dies at high rpm. It will run all day at moderate rpms. engine will start after several minutes of rest. exaust stream strong at mod. rpms. too rough to test at high rpms right now. 2nd engine running fine.
  #2
Old July 9th, 2005, 11:14 PM
rodbolt rodbolt is offline
Default Re: yamaha 2000 f115 4 stroke dies at high rpm
do you have the factory yamaha digitaal tachs and has the alrm system been tested? if its not an alarm issue its most likly going to be fuel. test the high pressure fuel rail while its acting up. the filter on the HP pump maay be clogged.
  #3
Old July 10th, 2005, 09:19 AM
fastcatch fastcatch is offline
the filter that is internal in the engine that is prior to entering the fuel injectors could be clogged. I had this problem with a 4 stroke 200 hp engine. This filter is the size of a nickel and very expensive to replace. over $1000. Shell gas payed for the repair for me because i was able to prove that this was the only gas i used. warrantee will not cover this problem because of contaminated fuel.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 225 OX66 dies at high speed gomezpet Yamaha & Suzuki Outboards 7 July 21st, 2009 09:45 PM
Where's the oil sending port on F115 Yamaha 4-Stroke? Arkapigdiesel Yamaha & Suzuki Outboards 14 July 7th, 2006 11:54 PM
Yamaha F115 4 stroke is it new for 2005 jk1162 Yamaha & Suzuki Outboards 1 July 25th, 2005 06:15 PM
Alternator output at 1000 rpm for Yamaha F115 4-stroke? bossee Yamaha & Suzuki Outboards 0 August 3rd, 2003 12:02 PM
Yamaha Experts-2000 Yamaha 225 OX66 EFI-WOT Dies wi1p Yamaha & Suzuki Outboards 2 March 12th, 2002 02:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
