  #1
Old July 8th, 2005, 12:29 PM
Lasse Lehtonen Lasse Lehtonen is offline
Default Yamaha 40 betol -91 cooling problem
I have a -91 yamaha 40 betol outboard and I have recognized that it is cooling poorly when warm.Ok the problem is this : When I start the engine cold the water is coming out of the pee hole normally, but when I have driven cruising speed for a while and then slow to idle speed the water stream coming out of the pee hole is wobly and there is not pressure at all.When I put a bit more throttle than idle it pisses just fine again.This is weird cause engine idle rpm is the same when cold (700rpm) and when warm but the pee-stream is much weaker when warm.The owerheat alarm have never sounded but Im stil a bit afraid.In cruising speeds the stream is allways normal and there is a lot of pressure. Thanks for answers.
  #2
Old July 8th, 2005, 06:14 PM
Triton II Triton II is offline
Ensign
Default Re: Yamaha 40 betol -91 cooling problem
Eki, the pee hole symptoms you describe sound completely normal. I worried about my FT60B doing exactly what you described and my dealer tank tested the engine and declared everything to be A-OK. Someone on this forum may be able to tell you exactly why the water stream pressure varies but it may be the water impeller has to push the water all around the engine once the engine is warm and the thermostat is open so the pressure reduces when warm? This theory sounds plausible, but I am not overly familiar with your engine so I could be talking out of my a&s!
  #3
Old July 9th, 2005, 12:37 AM
Thank you for answer. I hope it is not something more serious.I checked sparkplugs and they were all normal coloured (black) so I think water ending into the cylinder is not causing this loss of pressure in cooling system.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 40 Cooling mdjames@iee.org.uk Yamaha & Suzuki Outboards 2 September 3rd, 2005 01:19 AM
40/28 yamaha jet cooling ? Lee Timmons Yamaha & Suzuki Outboards 1 March 26th, 2005 02:42 AM
YAMAHA 1991 I/O cooling problem. bryont Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 11 April 12th, 2004 05:13 PM
5hp yamaha cooling problem miltoscy Yamaha & Suzuki Outboards 0 May 20th, 2003 04:25 AM
Yamaha 9.9 cooling AlexR Yamaha & Suzuki Outboards 2 December 29th, 2002 07:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
