I have a 15HP Yamaha 4 stroke that is 2 years old. It has never started easily, but last weekend it would not start at all. I could smell gas and thought it was flooded, so I disconnected the throttle linkage and tried starting with the butterfly wide open. That didn't work. After letting it sit overnight, I tried starting with no choke and it started running for about 10 seconds and then died. Squeezing on the primer bulb causes gas to drip out of the carburetor. Someone said it could be a stuck float. Is this something I can fix myself? Also, where can you get spark plugs for this motor? I checked with several marine supply stores and they don't carry them.<br /><br />Thanks,<br /><br />Bruce<br />San Jose, CA
