Thanks for your input bernieb. I installed a new Tempo gas tank last year, new fuel lines on the motor. I did not replace the fuel bulb or line. Installed all vent lines as required. New spark plugs and fuel filter. I did not replace the plug wires but I was thinking of doing that and decarboning when I rebuilt the fuel pump. I also replaced the oil injection pump. The thing is this motor runs great most of the time it only hesitates once in a while, a problem when trying to pull up a skier. I have a repair manual and I was going to check the timming advance after reading some of the other posts. I am not sure what you mean by be careful or I may lose it. The motor just hesitates just like a car when you press the accelerator fast and it hesitates before accelerating. You can hear that the butterflies are opening it just seems like it is not getting fuel. I am ordering the fuel pump kit and seafoam deep greep and I will see if that helps.
Again thanks for your input.
