  #1
Old May 31st, 2005, 07:24 PM
RedRustler RedRustler is offline
Default 2005 40tlrd 4stroke yamaha charging system
I have been away for a bit with the new motor i have been spending more time fishing and less tiime in the back yard trying to fix a problem my new motor has a 15 amp charging system and i was wondering if it would handle two battery's?it would be a trolling battery and a cranking battery with a switch box in between so i could only use the trolling motor while fishing and then switch to both battery's while running to give the trolling motor battery a little boost from spot to spot.i no-one see's a problem i was thinking of using 6 or 8 awg wire from the switch box to the trolling motor battery the box would be installed close to the cranking battery and be about a 11' run to the other battery
  #2
Old June 1st, 2005, 05:05 AM
rodbolt rodbolt is offline
Default Re: 2005 40tlrd 4stroke yamaha charging system
will physically work, not well ,but it will work. just dont switch batteries when the engine is running. 15 amps is not much but I guess its better than nothing
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2005 Mercury 90HP 4Stroke Outboards TheChad Non-Repair Outboard Discussions 1 June 28th, 2006 10:20 PM
1988 Yamaha 130 no charging system output fishon71 Yamaha & Suzuki Outboards 17 July 14th, 2005 08:06 AM
2005 4hp 4stroke merc idling and oil light Keith Storey Mercury & Mariner Outboards 0 June 24th, 2005 10:25 PM
Yamaha 25hp (2stroke)? Nissan 18hp(4stroke)? Honda 15hp(4stroke)? Spidybot Non-Repair Outboard Discussions 4 October 26th, 2003 06:22 PM
2000 Yamaha 200 hp OX66 Charging System Reelstock Yamaha & Suzuki Outboards 1 February 3rd, 2003 05:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
