  #1
Old May 31st, 2005, 12:31 PM
mcousart1 mcousart1 is offline
Default Yamaha 90 won't start+battery hot
I just got a 1998 Yamaha 90hp outboard on a 1991 Bayliner 1802 and it usually starts and runs ok but sometimes it won't kick over and the real concern is that the + battery terminal gets extremely hot when i'm trying to get it started. I'm afraid the battery could explode. I expect that I must have something connected to the battery wrong? The previous owner did'nt have this problem but he couldn't remember to proper connections. Here are the connections to the battery right now:- terminal: big black wire, small brown wire, small black wire+ terminal: big red wire, small white wire spliced to red, small black wire spliced to red.All other systems work fine with these connections. I assume that any wire that is red at the connection should be + but maybe not? What else could be causing the battery to get so hot and motor not always starting? Thanks.
  #2
Old June 1st, 2005, 05:23 AM
rodbolt rodbolt is offline
Default Re: Yamaha 90 won't start+battery hot
sounds like a bad cable connection someplace. loose or corroded. wire colors at the battery on most boats are crazy due to most people just add whatever wires are handy. you would not belive the amount of cut off household extension cords I see at the battery. but if the terminal is getting hot it indicates excessive resistance someplace or the starter is drawing to much current. I usually find a bad cable connection.
  #3
Old June 4th, 2005, 11:47 PM
31900 31900 is offline
If the battery terminal is getting hot, that is where the resistance is. Remove the clamps, clean the battery terminals and the clamps in a solution of bicarb soda. Reconnect and coat with vaseline.
  #4
Old June 7th, 2005, 08:02 AM
Thanks rodbolt and Adam1.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Start Battery / Tachometer jconnalyjr Boat Topics and Questions (not engine topics) 2 May 5th, 2004 04:22 AM
Start Battery / Tachometer jconnalyjr Electrics, Electronics and Trolling Motors 2 May 5th, 2004 04:22 AM
Wiring Battery to Start Boat john vigil Johnson & Evinrude Outboards 3 August 26th, 2003 08:31 PM
battery start conversion louisiannalyn Force & Chrysler Outboards 1 April 1st, 2002 01:57 PM
battery start conversion louisiannalyn Force & Chrysler Outboards 0 April 1st, 2002 10:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
