  #1
Old May 23rd, 2005, 07:32 AM
mcfly99 mcfly99 is offline
Default 225 Yamaha - Heads, Inner exhaust (with pic's)
This is actually a follow up to a previous post where I was replacing head gaskets, thermostats, etc.. Before moving forward I wanted to get some advice on the following:1) While cleaning the heads up last night I noticed (on one of them) on the very bottom, in between two bottom bolts where the water journal that flow around the head, you have a cavity between the two bolts. That cavity is corroded to the point it’s not as thick and not as “true” of a surface as the rest of the head, by the water journal. The corrosion is actually not on the water journal side but the side of the cavity between the two head bolts. A friend was over while I was working on this and he suggested marine tex to build it back up if I wanted to, as it looked to be on a side that is just an empty void. ??? (2) I removed the inner exhaust cover so that I could inspect the rings, etc.. All looks good, pistons, cylinder walls and rings. I do have some minor corrosion on the inner exhaust cover along with carbon build up. The corrosion was on the same side that I thought was breached.. (Although I never lost compression, it was the gaskets that looked suspicious to me.) Should I just clean it up and put it back in, or do I replace it?Thanks in advance!Fred
  #2
Old May 23rd, 2005, 04:29 PM
rodbolt rodbolt is offline
Default Re: 225 Yamaha - Heads, Inner exhaust (with pic's)
can ya take a good pic? and its possible if you will post the engine model # I may have a few heads in the scrap iron pile.
  #3
Old May 24th, 2005, 06:01 AM
Quote:
Originally posted by rodbolt: can ya take a good pic? and its possible if you will post the engine model # I may have a few heads in the scrap iron pile.
Hi Rodbolt,Thanks for the reply, I can take a picture tonight when I get home from work and post it. It's a 93 225 TXRR (pretty bad I know it off the top of my head).Thanks,FJM
  #4
Old May 25th, 2005, 07:05 AM
Hi Rodbolt, Decided I will keep my day job as my ability to take a "good" picture is questionable... Model is 225 TXRRHere are the photos http://photobucket.com/albums/y251/f...e&i nterval=4 Let me know the diagnosis!Thanks for all you help, it is appreciated.Fred
  #5
Old May 26th, 2005, 12:21 PM
One other thing I was going to ask.. I was going to add a water pressure gauge. Does it have to be a Yamaha or will any brand work. I was guessing that I would most likely have to deal with a metric size for the tubing?Thanks,Fred
  #6
Old May 26th, 2005, 06:57 PM
Ray Neudecker Ray Neudecker is offline
Any brand will work. The tubing will work. You may have to find the right fitting to go in the block.
  #7
Old May 27th, 2005, 04:25 AM
Quote:
Originally posted by Ray Neudecker: Any brand will work. The tubing will work. You may have to find the right fitting to go in the block.
Thanks for the advice. I stopped at the local marine surplus and picked up a gauge and the tubing kit. The fitting won't work, it needs to be metric. Talked to the local Yamaha mechanic, he told me the fitting compression fitting and tubing would need to come from yamaha. Cost @ $26.00... Cheap insurance.Any comment on the heads? Will Marine Tex work or do I need to replace?
  #8
Old May 27th, 2005, 04:35 AM
marine tex will work fine. just use a fine flat file on the surface when your done. it still has to be flat . aint saltwater great stuff the head must be level within .004 from end to end. use a straight edge like a small carpenters square and a feeler gauge.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pic's from our recent US visit Andrew Leigh Dockside Chat 19 January 16th, 2006 05:07 PM
Pic's link from Yahoo won't show after a while...? ST Non-Boating Technical Topics 3 December 9th, 2005 09:59 PM
Check out this project boat.......pic's kfraser Boat Restoration and Building 17 September 28th, 2005 04:54 PM
Transom repair Update[new pic's] dolluper Boat Restoration and Building 0 September 21st, 2005 07:05 AM
Yamaha 200. Can I mill cyl heads? milljo Yamaha & Suzuki Outboards 7 February 25th, 2005 04:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
