  #1
Old May 20th, 2005, 12:06 PM
jhthompson jhthompson is offline
Default 1993 Yamaha 15 HP 2 stroke water flow problem
My 1993 Yamaha 15 HP 2 stroke engine does not pass water through the "pisser" with muffs on and engine running. I found that the woodruff key was completely gone from the system when I removed the lower drive assy. The impeller looked fine although the fins were a litle curved, although it seemed to fit tightly in the pump cylinder. While loose I found the system was not clogged through the "pisser". When I put it back together, no output from the water pump. I tried both with muffs on and in a bucket. Any suggestions? TIA.
  #2
Old May 21st, 2005, 02:52 PM
Grant S Grant S is offline
Default Re: 1993 Yamaha 15 HP 2 stroke water flow problem
On my 8hp yammie I had a similar problem, even though the impeller looked ok. I replaced it. Make sure that the water level in the bucket is higher than where the water pump is in the leg.
  #3
Old May 22nd, 2005, 02:11 AM
31900 31900 is offline
The hose from the motor to the telltale outlet can become blocked.Check it out by removing it and blowing through it or clearing it with a piece of thin wire. Some insects love to block it with mud after laying eggs in there.
  #4
Old May 22nd, 2005, 06:03 AM
Thanks Grant S: I recently ordered a manual for the engine so I can purchase the impeller next. Does your yammy shoot out water from the pisser as soon as you start up,when the motor is cold?
  #5
Old May 22nd, 2005, 06:05 AM
Thanks Adam1: I believe hat I did do that by running water up through the tube when the lower end was off.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 225 4 stroke exhaust flow ggidzinski Yamaha & Suzuki Outboards 1 June 23rd, 2006 03:21 PM
Water flow direction sl750 Polaris 1993 Donczar PWC (Jetskis, Waverunners, etc.) 1 June 6th, 2006 05:27 PM
2001 Yamaha 90HP 2 stroke 90TLRZ - water flow question dpfundst Yamaha & Suzuki Outboards 1 May 1st, 2006 10:34 AM
Idle Hole water flow on Tohatsu 9.8 2-stroke yynhymr Honda & Tohatsu/Nissan Outboards 4 March 6th, 2006 05:33 PM
1993 X-flow water in cylinder looper power Johnson & Evinrude Outboards 2 April 15th, 2005 10:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
