Thanks for the input guys.
I will check later today and repost.
Also, Rodbolt yesterday I ran the test that you gave me on the April 23
Your test" so far the only abnormal symptom you have given is the buzzer sounding when transfering with the emergency switch, should not happen.
by the fact that the pump can be manually run it tells me the wiring from the connector at the engine to the pump is good. the brown wire to the remote tank is 12+ with key on. the blue wire is the ground path for the CDI and the manual switch. when moving the switch your manually grounding the circuit. with the key on test for 12v at the bluegreen and blue white wires. if you have 12v hit the toggle for emergency transfer and watch the voltage on the system. you may be fighting a main harness problem. use a 12v test light and unplug the connector near the main harness with a yellow wire, blue wire, black wire and black/red. it may be a brown depending
.set up a test light between the blue and the brown or the blue and the yellow on the engine plug. turn the key on. light should be off. switch the emergency switch on, should have a light. now with key still on jump the blue/green to ground. should have a light. jump the blue/white to ground, light should go out.
CDI failures are rare. ground failures and harness failures not so rare. and you swapped the CDI and no change in problems. do you have a service manual for the engine ? "
I have 12+ at the blue white and blue green wires. When I hit the emergency transfer the voltage drops to ZERO on both wires and the buzzer and light come on. When I ground out the wires the buzzer and lights come on. I set up the test light between the brown and the blue on the engine plug. I ground the blue green, no light, but tach buzzer and lights come on. Gound out the blue white no light, but tach buzzer and lights come on.
Does any of this information give you other leads on what other wires to check for shorts or ground failures.
Thank you
Carlo
