  #1
Old May 14th, 2005, 12:05 PM
rayrayman64 rayrayman64 is offline
Default battery cable install on 90 yamaha 2 stroke
Hey guys, I am installing a 90hp 2005 yamaha on my boat and am confused about the diagram in the service manual as to where to hook the battery cables to the motor. Do I hook the posative lead to the starter relay and the negative cable to the starter housing? To put it plainly Where do I hook the battery cables to? And where do I hook the 12 gauge red wire with the fuse holder on it, coming off of the 10 pin harness on the engine side? I believe this goes to the "hot" side of the battery as well, but I want to make sure!!!. Does anyone have a rigging guide? I have the service manual and the online parts manual, but can't find the proper info. PLEASE HELP ASAP!!!! :0 Thanks, Ray
  #2
Old May 14th, 2005, 12:50 PM
rodbolt rodbolt is offline
Default Re: battery cable install on 90 yamaha 2 stroke
yes the positive cable attaches to the post on the starter solinoid opposite the post with the starter cable. the red wire with the fuse goes to the same post as the batt cable on the starter solinoid. the ground batt cable goes to the starter bracket at the top of the starter. you will see a small boss with an 8mm threaded hole. the fasteners should have come with the engine.
  #3
Old May 15th, 2005, 03:59 AM
Thanks Rodbolt!! You have been a real blessing since I joined this post!! God Bless Brother!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 115 4-stroke tach install SRS15 Yamaha & Suzuki Outboards 10 February 13th, 2006 06:28 PM
1999 Yamaha 90HP(2 stroke), not charging battery gst Yamaha & Suzuki Outboards 9 November 1st, 2005 04:41 AM
yammy 90hp 2 stroke 703 throttle/shift cable install rayrayman64 Yamaha & Suzuki Outboards 1 May 4th, 2005 05:28 PM
2000 Yamaha 9 HP 4 stroke pull cord to charge battery? DjPro Yamaha & Suzuki Outboards 2 June 1st, 2004 08:48 AM
shift cable install??????? dougcars02 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 4th, 2003 11:19 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
