  #1
Old May 3rd, 2005, 12:39 PM
superteddan superteddan is offline
Default Yamaha F90 2004 electrical problem
Hi. Have a Yam F90TLRC (2004) which I just purchased. I have it all hooked up (in my garage) with controls, battery and the whole nine. I get battery power to all feeding points on relays etc, but I can't get anything to happen, not even tilt action by pushing the button on the actual engine house. I don't get even a click. Nothing works from the control either - tilt, cranking or whatever. Battery feeds about 15 volts to all vital points, and fuses are good. Bought it from a private seller (from a distance), who isn't a tech either, and worked fine (he says). Thing is hardly run, and looks brand new wherever you look. I am clueless on this one - I must be missing something obvious. Anyone have any ideas? Thanks.
  #2
Old May 3rd, 2005, 04:03 PM
rodbolt rodbolt is offline
Default Re: Yamaha F90 2004 electrical problem
look at the inline fuse near the starter solinoid. and what vital points are you testing? does the tach selftest and light up? 15 volts indicates ya got something way way wrong. battery voltage is only about 12.5 or so. with the key on go between the black wire and yellow wire. should show battery voltage. what control/ign harness are you using ?
  #3
Old May 4th, 2005, 02:49 AM
Thanks for your reply. I check at e.g. feeding point at the relays for the trim/tilt. Battery is at about 15V (externally charged, charger produces at around 14,8-15). As soon as you put a load to it, it of course falls to about 13 or so - pretty much like in any of my cars. Most chargers or alternators - in my experience - charge at 14-15. I'll check according to your suggestions and get back. BTW, I am using the 703 control and the digital tach/speedo.
  #4
Old May 4th, 2005, 03:04 AM
ok on the pigtail from the 703 you will see a green wire,yellow wire a black wire and a red wire. hook your meter up between the black wire and the red, should have 12 volts. then black to yellow with key on. should have 12 volts. if no voltage is present go back to the starter solinoid and make sure the correct wires for the 12v power tap is on the correct post and insure the inline fuse is good. and dont test anything with the battery charger on. gives false readings.
  #5
Old May 4th, 2005, 02:08 PM
Thanks! Will do some testing soon, hopefully tomorrow. Just to be certain, when you say inline fuses, I suppose you mean the 2 guys above the relays, close to the starter? Checked the wiring diagram in the shop manual, and I can only find those two. Another question, while I am at it - even if I only have the battery connected, no control or gauges, the tilt switch on the motor housing should work, right? Again, according to the diagram, it should be pretty straight forward, the wiring to that switch is just parallel to the one on the control. Anyways, I'll dig according to your instructions and we'll see what comes out of that. Thanks again.
  #6
Old May 5th, 2005, 01:59 PM
Well, something happened, although I don't know exactly what. Hooked everything up today, to do some further testing, and everything works - just like that. I am clueless as to what the problem was... hopefully it doesn't reappear once I am out with the boat. Thanks for the kind help!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 115 overheating or electrical problem proline190 Yamaha & Suzuki Outboards 8 December 31st, 2006 08:00 PM
2004 25 hp 2 stroke yamaha idle problem speckman25 Yamaha & Suzuki Outboards 0 May 14th, 2006 03:52 AM
yamaha 2001 115 electrical problem vineyard Yamaha & Suzuki Outboards 4 November 26th, 2004 04:48 PM
Tilt and Trim Problem 2004 Yamaha TiltTrimProb Yamaha & Suzuki Outboards 1 July 3rd, 2004 03:27 PM
40 hp YAMAHA with electrical problem spark plug Yamaha & Suzuki Outboards 1 May 26th, 2004 11:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
