  #1
Old March 15th, 2005, 05:56 PM
John Christopher John Christopher is offline
Default Yamaha 200 False Alarm?
I have a 1996 Yamaha 200 Saltwater Series (since new), 580 hours, professionally and regularly maintained. Recently, the overheating alarm has come on every time I run it up over 4000 rpm. There is a good stream of water coming out and it is cool. My mechanic is scratching his head. Is it possible the sensor and/or the alarm are the problem?Thanks. John
  #2
Old March 15th, 2005, 08:25 PM
seahorse5 seahorse5 is offline
Default Re: Yamaha 200 False Alarm?
A professional and trained Yamaha mechanic scratching his head on a 9 year old motor with an overheating problem???? Now if it was a "carport cowboy" or a "I can fix anything" type of "mechanic" that is understandable.Has the motor been run using an infrared temp gun to see the exact temperature that each cylinder head is operating at?Were the the water pump and thermostats replaced? If so, was a complete factory water pump kit installed, or just an impeller? What did the mechanic find when he serviced the poppet valve assembly? Did he install the new style valve?Have the temp senders been removed and tested in a pan of water?Are there any tranducers, or thru-hull fittings within 17" of the motor centerline that may affect clean water flow to the gearcase water inlets?Have the cylinder heads been taken apart and the passageways cleaned out if the motor was used in saltwater?
  #3
Old March 16th, 2005, 02:03 AM
rodbolt rodbolt is offline
what seahorse says. and is he certain its overheat? what visual indicators are lit?
  #4
Old March 16th, 2005, 07:15 AM
I see.....Will have a discussion with the mechanic and had better start going about things methodically. But are sensors and alarms known to fail over time? (it's the red temperature indicator which lights up)
  #5
Old March 16th, 2005, 11:27 AM
kavika kavika is offline
My 1997 had similar problem.Did all the above [under the mechanic's shade tree who used hand rather than IR temp gun]: new water pump assembly, new therms, tested sencors, cleaned poppet. Still overheated when run over 4000 for ten min. Alarm audible, red indicator, and de-powered [limp home mode]. Run all day at 3600. Applied green poltice $$. Took it to dealer who took off the head and small obstruction next to stb senser. No damage.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
(Mostly) False alarm. JB Dockside Chat 5 August 8th, 2006 10:29 PM
False alarm Terry H Non-Boating Technical Topics 7 May 22nd, 2005 06:27 PM
yamaha eng. alarm help puddle pirate Yamaha & Suzuki Outboards 11 January 13th, 2004 05:27 PM
False overheat alarm, I hope! Other causes? Black85L98 Mercury & Mariner Outboards 2 August 13th, 2003 06:14 AM
1986 Johnson 150 False Overheat Alarm ?? Brentvo Johnson & Evinrude Outboards 1 July 13th, 2002 12:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
