  #1
Old March 7th, 2005, 06:24 PM
gstyler1 gstyler1 is offline
Default Yamaha 25 HP 4 cycle Carb Problems ??
Hi, This subject was posted by "tjtraver" on 2002-07-03. I was wondering Todd, if you had any successful outcomes, because my motor is doing the exactly the same thing! I have pulled the carby apart and everything looks 'in order', also all the fuel lines are clear. After about 20 minutes flat stick, she dies. Any help would be much appreciated, as before this problem the motor has never let me down. "I have a 4 or 5 year old yahama 25 hp 4 cycle engine that starts and runs fine for about 30 minutes ... then the engine quits running and has fuel running out the overflow from the top of the carb... Anyone have ideas what's going on here ? Is it somehow fuel presure related ? Any insights into this problem appreciated ... Thanks, Todd Traver"
  #2
Old March 7th, 2005, 07:06 PM
rodbolt rodbolt is offline
Default Re: Yamaha 25 HP 4 cycle Carb Problems ??
hello most likly trash in the fuel lines or a bad needle/seat or a faulty float. time to test not a hard job but sometimes must be done.
  #3
Old March 8th, 2005, 06:43 AM
alotto alotto is offline
Had the same thing.Turned out to be a float needle valve problem.Disasemble the carbs carefully and check and clean all the float parts in each of the carbs. I had 4 carbs on my 50 4 stroke Yammy. These guys have a habit of gumming up for no apparent reason.
  #4
Old March 9th, 2005, 02:00 AM
thanks for the advice. I will let you know the result....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 60-40 jet injected 4 cycle vs merc 90-65 2 cycle carborated.. ffffg Non-Repair Outboard Discussions 1 May 30th, 2006 10:57 PM
Yamaha 9.9 fourstroke carb problems mike white Yamaha & Suzuki Outboards 0 April 5th, 2006 05:52 PM
Yamaha VMAX Carb 150 - Idle Problems when hot Atlanta Boater Yamaha & Suzuki Outboards 7 May 19th, 2004 02:47 PM
Yamaha VMAX Carb 150 - Idle Problems when hot Atlanta Boater Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 May 17th, 2004 04:28 PM
Yamaha 25 HP 4 cycle Carb Problems ?? tjtraver Yamaha & Suzuki Outboards 1 July 3rd, 2002 10:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
