  #1
Old February 5th, 2005, 01:42 PM
crabman333555 crabman333555 is offline
Default Revist aluminum to SS prop
Thanks for you comments on my earlier post. I am confused as ever, but not so muchbecause of your post, as my vist to A/C boat show yesterday AFTER my original post. I talked with 5 vendors, including 2 Yamaha reps, and came away with differenct "EXPERT" opinions, including the Yamaha guys who even disagreed with each other. How is that for a headache? Again, my situiation:22' C-hawk sport cabin, w/Yamaha 150 hp 3 blade aluminum prop (14 1/2 X 17) = 5100-5200 rpm's. Manual calls for 4500-5500 for 2 cycle motor 2003 model. They all agree, turning less than 5000 r's, loading engine, shortin life of motor. Over 5500 also no good, same results. ALL say same prop in SS will LOSE rpm's so different dia & pitch will need to change, but all say different specs. Now these people are "EXPERTS". Confusing huh? One Yamaha expert says I must be at 5500 exactly. BULL. So, now where do I find RIGHT scoop?
  #2
Old February 5th, 2005, 09:31 PM
walleyehed's Avatar
walleyehed walleyehed is offline
Default Re: Revist aluminum to SS prop
It's at the end of the other post.....This isn't my first day on the boat, and most dealers don't test near the number of props I do.The diameter issue can raise questions as to where to mount the engine height-wise for optimum performance. A direct replacement (if there is such a thing) in SS is most likely going to be "slightly" less diameter, and yet we can choose to go with a larger diameter if lower end performance is needed, which "may" require raising the engine a hole or 2, to maintain performance benefits we are trying to keep....do you see where I'm going with this???There is no such thing as a "cover-all" prop.Just removing the alum prop and installing an SS prop is not the answer in most cases. Look at my recommendation on the other post if "just changing over to SS" is all you want to do....If you want more, post back and we can get a bit more info and I'm 99% sure we can point you in the right direction.
  #3
Old February 6th, 2005, 01:03 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
The one(s) that told you that a stainlness of the same pitch will turn fewer RPMs than an aluminum is simply wrong. You either misunderstood or you weren't talking to an "Expert", just a lowly Salesman.2-strokes like RPMs. Naturally if you run the motor too fast, things will break. If you lug them too much, then you'll do other internal damage. Neither of these are Wear issues. You're within the range at 5200 and probably worrying over nothing. The closer to the top of the range, the more usable horsepower you'll get. Any motor needs the proper RPMs to get the full rated horsepower. Running a 150 at less than that is developing less than 150 horsepower. At 5200, you're awfully close. (You didn't hear this from me but 150 Pro-Vs will run all day long at 6,000.)
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #4
Old February 6th, 2005, 05:30 AM
shep70057 shep70057 is offline
One misconception when switching over is that people lose R's. That may be so, but it's not because of the pitch on the SS. It's just that it doesn't flex as much as the aluminum. A smaller diameter prop may be the ticket. My Suzy 150 doesn't like those large diameter props.
  #5
Old February 6th, 2005, 06:50 AM
walleyehed's Avatar
The diameter has more to do with how the rig is set up... if you increase diameter- or decrease..-without adjusting anything else, the results may not be favorable.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
SS or Aluminum prop? SnookHunter Prop Questions and Topics 5 October 27th, 2006 12:13 PM
a few aluminum prop questions Ripfence Prop Questions and Topics 6 July 6th, 2006 03:34 PM
Best aluminum prop? captnpgn Prop Questions and Topics 2 March 14th, 2006 04:22 AM
Aluminum Prop $125, Stainless prop $2600 SeaHorse Non-Repair Outboard Discussions 20 July 18th, 2004 09:41 PM
Best aluminum prop? bassinbrunner Boat Topics and Questions (not engine topics) 6 March 27th, 2004 09:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
