mclamore,
Along with looking very closely at everything, it seems like the pistons/rings for those cylinders should have something wrong with them to be forcing the crankpin end of the rod upward.
This check should follow the check of the bottom bearing as rodbolt suggests. The shaft running too low on a (badly) failed bearing would give you that and maybe the broken piston you've found.
