anchor questions
simple
1. What's the recommended scope for calm to fair conditions? Is 3 to 1 enough?<br /><br />2. Do you people prefer the plastic dipped chain over the galvanized type? I was thinking the dipped type would be less damaging if it were to come in contact with the hull.
ziggy
Re: anchor questions
the power squadron teaches that 7:1 is average. don't for get that yer boat is above the water some. so ya need to add that into yer equation for lenghth of rode.<br />chapmans piloting book calls for no less than 4:1 in fair conditions and 5-7:1 in average conditions and 10:1 in heavy conditions.<br />it seems there are many factors to consider when achoring, but these numbers seems to get us started.....<br />as far as the plastic dipped stuff. i don't know. seems to me the plastic would perhaps better potect yer boat. myself, i just have a plain chain but have to be careful when pulling it up as the chain will certainly contact the hull if i don't, and i don't want that.....
imported_Curmudgeon
I think it depends on the water depth and current - I've found the deeper it is, the more scope is required, the more current when putting it out, the more scope needed. 7:1 is a good rule of thumb for heavy weather; inappropriate for a tight anchorage and unnecessary for most open water applications. I think vinyl chain is subject to air entrapment, which sorta defeats it's purpose. Had a hard time setting the anchor where I usually fish, dumped the vinyl for galvanized of the same size/length and haven't looked back.
QC
I'm with Old Curmudgeon on the vinyl and the tight anchorage deal. That's why I want approximately the boat's length or more in chain. Adds a little security to less scope. I must use 2:1 scope often. I have to be very delicate and not power down to get it to set, it can be scary and I watch for dragging constantly.
simple
Originally posted by Old Curmudgeon:<br />I think vinyl chain is subject to air entrapment, which sorta defeats it's purpose.
Interesting point. I never thought of this. So, you're saying that if the vinyl gets nicked or worn away, air can get under the vinyl which would cause it to be not as heavy?
magster65
I anchor in tidal currents and sometimes windy conditions. I usually go with 5 or 6:1 if there's room and prefer the danforth anchor to any of the others (even though I currently have a plow style). Never tried any other chain than galvanized and yes, it'll scratch the heck out of your boat if you're not careful.
Chris1956
Simple, It appears you do you boating on lakes. If so, good galvanized chain will resist rusting in fresh water, with minimum maintenance on your part. If you are anchoring in calm to fair conditions on sand or soft bottom, and can get a good scope (5::1 or greater) you can skip the chain. Today's fluke anchors hold extremely well without chain.
SwampNut
No, it's full of air all the time which can't escape when you put it in the water. Nicks and scrapes would help let the air escape.
magster65
The Delta looks like mine except that mine has the swivel on it. I haven't had any problems with the plow it's just the danforth is so much lighter... but then again the danforth doesn't work on a rocky bottom very well. Ideally, I guess a person would have one of each :)
phantoms
I've always worried that the dipped chains were not protected in any way other than the dip coating, meaning that if a tear in the coating were to happen, corrosion would attack the chain. I've always used galvanized for this reason. I don't know this to be the case, but none of them I've seen state what type of chain they use.
18rabbit
Plastic coated chain is for pretty boats that never drop anchor. If you intend to drop anchor, inevitably, the plastic coating is compromised, water gets in between the steel and the plastic, is held there, and rust happens. You won’t be able to see the rust and at some point, the chain separates. Probably takes awhile, but it will eventually happen. Best to just stick with galvanized chain.
rwidman
......... good galvanized chain will resist rusting in fresh water
It won't rust in salt water either. That's what the galvanizing is for. ;)
Chris1956
rwidman, all metal corrodes in salt water. The only difference is the time it takes. Galvanized chain will rust, aluminum turns to powder, brass pits. Even Stainless Steel corrodes to some extent. Lead is pretty resistant to rust, but makes a bad anchor chain and an even worse bow eye.
navigator336
All titanium, that's the way to go. Strong, light, won't corrode. About a $1000 a foot. You can be anchoring in style for say, ... a quarter million!
heycods
Polly floats as I presume does vunyl.
magster65
Originally posted by navigator336:<br /> All titanium, that's the way to go. Strong, light, won't corrode. About a $1000 a foot. You can be anchoring in style for say, ... a quarter million!
:) <br />ah haha<br />Save a fortune and beach it!
