  #1
Old December 12th, 2004, 02:08 AM
John from Madison CT John from Madison CT is offline
Default Yamaha VST Filter cleaning with Photo
Rodbolt and Ray: This photo above is of the VST filter on my '98 Yamaha 250hp OB. I believe it's never been cleaned after at least 500 hours of use, probably more. You can see at the bottom of the filter where I pushed away the dirt with my finger. The "whiter" part if the filter element underneath the dirt.My engine started acting up last year in which it would hesitate or drop RPM's for a very short instant, after hitting a boat wake or wave, then resume just fine. Some days each and every wake or large wave would show this hesitation, and at speed, would make you lunge forward in the boat. This began after my first large load of Ethanol laden fuel.Anyway, as an FYI, I found that those small Phillips screws on the VST tank are a beast to get out. I was beginning to strip a few and was real nervous through the process. I ended up having to remove the tank off the engine and bring it to my work bench to get those screws out. There was no way I could do it while the tank was still on the engine. Funny thing was that these screws were Not corroded at all, just in there tight.Also, it seems the gasket (the thin long one) stretched a bit so I will need to replace it.I am leaning on cleaning the filter with soap and water and air drying it well.Any advice you have would be very welcome.Regards,John
  #2
Old December 13th, 2004, 04:51 AM
Ray Neudecker Ray Neudecker is offline
Default Re: Yamaha VST Filter cleaning with Photo
At this point,replacing would probably be better than cleaning. Rodbolt has a lot more experience with them and may have a different idea, but I haven't had good luck cleaning when they were as dirty as that one looks.
  #3
Old December 13th, 2004, 10:32 AM
Robert Finch Robert Finch is offline
I have same engines, same year etc., and want to do same service on VST but service man. does not give me a very good step by step layout. Can I ask where you started, I would guess you drained the gas and started taking apart, are you also changing the little final screen (or filter) on top and then just refill with gas, or do you just start and the lower pressure pumps will refill, all questions not sure about. Any help would be great. Thanks
  #4
Old December 13th, 2004, 01:38 PM
Red Reg: First I got the manual, that will help somewhat. Then I just looked at the whole assembly to understand what goes where. There are 3 bolts that hold the VST to the block. They are hard to get to, but you can do it with some patience. Once these come out, the VST kinda just hangs there. I tried to get all the little philips screws off at that point, but a few got stuck, so I had to disconnect all the hoses and a couple of wires to take the tank to my bench. With some luck, I got all the screws out. The lower part of the VST tank just drops off. The filter is at the bottom and twists off. I will probably take Ray's advice and buy a new one so I start fresh. As for refilling the tank, I assume that if you just pump the bulb and crank the engine that the fuel and oil will mix properly and the tank will fill that way. Perhaps it may be better to add some premix to the whole thing beforehand ?? That's a good question for Ray and Rodbolt.John
  #5
Old December 13th, 2004, 04:13 PM
Thank you, that helps, so is it your understanding that the only thing that needs to be serviced in the VST is really just the changing of the "pressure pump filter. I see in the VST/Pressure Regulator diagram there is another small filter and o-ring on top of the VST in the pressure regulator, have you looked at that, or is that also in you service plans?
  #6
Old December 14th, 2004, 12:54 AM
RedRad: After I read your post last night i decided to get to that little filter you refer to. After 5 minutes, I got to it and noticed that it was basically clean. It is not as fine a mesh as the VST Pump filter.John
  #7
Old December 14th, 2004, 04:27 AM
No real reason to add pre mix. Pumping the bulb and starting the engine will do the job.
  #8
Old December 14th, 2004, 08:10 AM
Thanks Ray for that info. John give us an update when you put it all together and test run it. My engines are doing the same thing you describe in your first posting. I see you are also in CT, I am sure I am getting the same problems from this new fuel. I have heard things like the engines need to run hotter, with hotter plugs etc to handle the water that the Ethanol absorbs...just what I hear not sure which plugs would be hotter than what yamaha specs say to use. Sounds like that VST filter will be the thing that will need the most attention from this new fuel?
  #9
Old December 14th, 2004, 09:02 AM
Red Reg: Where are you located?Ray: If you pump the bulbs, won't the VST fill with pure gas and no oil? Would it be wise to just turn the key and let the engine turn over so the oil pump gets engaged?
  #10
Old December 14th, 2004, 10:00 AM
Rowayton, CT
  #11
Old December 14th, 2004, 11:11 AM
That's part of Norwalk, right?
  #12
Old December 14th, 2004, 11:22 AM
Yes it is the little harbor inside the light house.
  #13
Old July 20th, 2009, 07:51 PM
dkortum dkortum is offline
Thumbs up Re: Yamaha VST Filter cleaning with Photo
Thank YOU for this post! Changing the filter on the bottom of the fuel pump inside the VST solved my problem with a 2000 250 hp Yamaha. We had the same problem with surging, especially when hitting a wave. Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Cleaning VST filter? SPYKE-KPT Yamaha & Suzuki Outboards 2 August 1st, 2006 01:46 PM
cleaning carbon from yamaha 115 k5ranger Yamaha & Suzuki Outboards 3 March 29th, 2005 11:05 AM
Yamaha 15hp remotes question-see photo Rudderman Yamaha & Suzuki Outboards 0 September 25th, 2004 02:17 PM
yamaha 130 carb cleaning gator79 Yamaha & Suzuki Outboards 8 January 15th, 2004 11:09 AM
4 hp yamaha air filter? tm Yamaha & Suzuki Outboards 1 July 13th, 2002 04:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
