hello
I suspect rather than a precision blend failure we are dealing with a customer neglect failure.
much more common than pump failures.
somewhere in your service manual there is an oil consumption test. all the tests require the engine to have a 50-1 premix while running the test.
I cannot remember the output specs but you unplug the hose downstream of any inline check valves,if used, and run the engine at the specified RPM for the specified time and collect the oil. the details are in the manual. but remember he pre mix while doing it.
