  #1
Old November 18th, 2004, 09:32 AM
Lee Strong Lee Strong is offline
Default Yamaha ignition switch wiring
I have a Yamaha 9.9 FT9.9EXJ S/N 6G8 UL 780693While troubleshooting startup problems, I replaced the stock 6-terminal ignition switch with a basic switch that has 3 positions and 3 terminals (B/I/S), and connected:Red to BatteryWhite to IgnitionBrown to Starter It starts & runs strong, but won't quit when I turn the key off! Should I connect a ground to the switch ? Which terminal ? Or should I buy another 6-terminal switch ? http://www.iboats.com/mall/index.cgi...****=146058713 Or a more expensive Yamaha stock switch? I do not need to wire accessories or choke.Thanks in advance to anyone with an idea.
  #2
Old November 18th, 2004, 12:35 PM
rodbolt rodbolt is offline
Default Re: Yamaha ignition switch wiring
hello hopefully you have not damaged anything. we shall see. the switch you used will not work and is not wired properly. yellow is key on power,white is kill, black is ground, brown is start, blue is choke, red is fused 12v positive,pink is to the alarm horn. you must use a switch that in the off position connects the black to the white. will be M terminal on a jonny/rude type switch. I guess it will be to easy just to order the correct part hopefully the improper voltage on the stop circuit wont hurt. good luck and keep posting
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Wiring an ignition switch blackwaterstout Non-Repair Outboard Discussions 3 September 5th, 2005 08:28 AM
Ignition switch wiring bblalock Force & Chrysler Outboards 7 November 16th, 2004 12:59 PM
Ignition Switch Wiring gwetzell Johnson & Evinrude Outboards 6 August 22nd, 2002 09:26 PM
ignition switch wiring stinger1 Mercury & Mariner Outboards 6 August 9th, 2001 06:27 AM
ignition switch wiring stinger1 Non-Repair Outboard Discussions 0 August 7th, 2001 08:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
