  #1
Old November 14th, 2004, 04:19 AM
John from Madison CT John from Madison CT is offline
Default Yamaha Oil Reservoir Filter/Strainer Replacement
I'm long overdue on much maintenance for my '98 Yamaha EFI 250hp OB. One thing I've forgotten for a few years is the Oil Reservoir (3gal tank) filter/strainer. From a blown up diagram over at www.boats.net it appears that the filter is very small part, very close to the pump itself. Since the pump is hidden behind the tank, the tank probably needs to be moved off it's mount and access is needed to the rear. Has anyone ever done this filter replacement themselves and am I missing something obvious? Thanks, John
  #2
Old November 14th, 2004, 05:06 AM
Osprey Osprey is offline
Default Re: Yamaha Oil Reservoir Filter/Strainer Replacement
John,You are correct. The filter is a small inline unit, black, that looks almost like a hose coupling. The pump, hoses and filter are recessed into the outside of the tank. You will need a couple small wire-ties as well.Since it will need to be removed anyway, take the opportunity to drain all oil and wash out the reservoir. You will be surprised how much sludge is likely in the bottom of the tank. Dish soap and hot water works fine. Then let dry before reassembly.
  #3
Old November 14th, 2004, 03:45 PM
rodbolt rodbolt is offline
hello while we are dealing with neglected maint. when was the last engine oil tank water trap service? when was the last VST filter service? when was the last O2 sensor service? and when was the last low pressure fuel pump rebuild/replacement? all of the above can cause catastrophic piston failures. good luck and keep posting
  #4
Old November 15th, 2004, 12:47 AM
Rodbolt: I've heeded your warnings and have begun the process of maintenance on my Ox66. I cleaned the O2 sensor a week ago. This was done after probably 600 hours of engine use. Remarkably, it was very clean. No obvious signs of carbon build up on the sensor, it's housing or the transfer tube. Next is the VST filter replacement. I need a warmer day to do that, but I now know how to do it. Over the winter, the low pressure pumps are being replaced too, just for normal preventative maintenance.
  #5
Old November 15th, 2004, 02:42 AM
good deal. stay on top of the maint and most of those motors live a long and happy life
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Trying to test a Yamaha remote oil reservoir pump ... RodBolt, anyone? nickfishbait Yamaha & Suzuki Outboards 3 October 17th, 2006 09:45 PM
Raw water intake strainer; 2 engines on 1 strainer?? mduff1116 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 14th, 2006 08:10 AM
Yamaha 200 HPDI Oil Reservoir & Steering ltfinney Yamaha & Suzuki Outboards 4 March 11th, 2006 04:29 AM
Trim/Tilt .. Reservoir replacement r1gal Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 December 9th, 2005 02:38 AM
115 HP Yamaha V-4 Oil Reservoir jraquel Yamaha & Suzuki Outboards 1 April 10th, 2003 06:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
