  #1
Old November 7th, 2004, 04:09 PM
milljo milljo is offline
Default Getting water in one cylinder, 200 HP Yamaha
It appears that water is getting into one cylinder of my 200 HP Yamaha ('96 model used in salt water) Even a new plug will foul after several hours of running. It is the top plug on the port side. All of the other plugs look OK. I have had this boat for 9 months now. It worked fine until about 3 months ago when the plug started fouling. My inclination is to remove the head and see if I can find the source of the water. So my question is:Any special considerations/techniques to removing the heads on a 200 HP Yamaha? It appears to be straight forward. Is there a particular sequence for removing (and replacing) the head bolts? Any assistance will be greatly appreciated.
  #2
Old November 8th, 2004, 01:49 AM
rodbolt rodbolt is offline
Default Re: Getting water in one cylinder, 200 HP Yamaha
hello are you sure its water? water will clean a plug but not foul it. also if its saltwater and you carefully inspect the ground electrode you will see green flecks.are you positive its water? it can be a head gasket leak or a leak in the exhaust divider plate. the only trick is to carefully clean all gasket surfaces. do not use wire. I use the 3m pads on a drill. then use acetone or a carb cleaner that does not leave a film. rubbing alchohol will work. after cleaning its imperative to check the surface flatness of the head and the flatness and integrity of the aluminium around the cyl sleeves. other than that the torque sequnce and specs are on the head as well as your service manual. good luck and keep postingif its oil fouled check the plug caps and the recirc chek valve for that cyl. not all v yamahas used the check valve, a good way is to look in the parts diagram and see if they call that fitting on the block a nipple or a check valve. good luck and keep posting
  #3
Old November 8th, 2004, 03:52 AM
Ray Neudecker Ray Neudecker is offline
The head bolts should be replaced in the sequence indicated on the heads and shown in the manual with proper torque. Note that the problem can also be caused by a carb problem if this is a carb motor,
  #4
Old November 8th, 2004, 02:13 PM
Thanks for the info Rodbolt & Ray. I thought I have a water leak but now I'm not so sure. I don't mind removing the head & replacing the head gasket but I have never worked on an outboard engine of this type and am not sure of the potential problems. I have been reading a lot of posts about breaking off head bolts, etc. and would hate to get in a worse condition than I am. Does anyone have any tips/techniques for removing heads without busting bolts?
  #5
Old November 8th, 2004, 02:36 PM
First I would do a compression test to see if there is any reason to pull the head. If the plug is black and fouled. You are most likely working on the wrong end of the motor.
  #6
Old November 9th, 2004, 01:42 AM
what ray says. try to post a pic of the plugs
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Who has a 3 cylinder 40hp Yamaha? gov2mod Yamaha & Suzuki Outboards 8 January 20th, 2009 07:48 PM
01 yamaha lost #2 cylinder A Bite Yamaha & Suzuki Outboards 5 October 13th, 2006 08:47 AM
Water in Lower Cylinder & Water Alarm Beeping jeffnomme Yamaha & Suzuki Outboards 13 June 8th, 2005 01:35 PM
Lazy Cylinder on Yamaha 150? jasonalden Yamaha & Suzuki Outboards 22 July 24th, 2004 12:51 PM
Yamaha Water in Lower Cylinder jktrahan Yamaha & Suzuki Outboards 3 March 24th, 2004 04:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
