  #1
Old October 11th, 2004, 03:48 PM
kkilloy kkilloy is offline
Default Yamaha 100 four stroke engine oil leak while tilted!
I have a 1999 Yamaha F100 HP four stroke outboard. I change the engine oil (10w-30 Castrol and Yamaha brand oil filter) and lower unit oil annually and the engine has performed great. Boat stays in the lake all summer and is used at least twice a week. Last week I noticed motor oil in the self bailing area of the rear of the boat. The oil runs out around the area that the large steering arm connects. It only leaks while tilted. It is very hard to tell where it is leaking. I am guessing about 1 to 2 ounces per week. The engine is very clean and runs beautifully except for the oil leak. Any help would be greatly appreciated.Thanks, Kevin
  #2
Old October 11th, 2004, 03:56 PM
rodbolt rodbolt is offline
Default Re: Yamaha 100 four stroke engine oil leak while tilted!
hello does the oil level on the dipstick drop? when you changed the filter did any oil spill?that is a new one as 4 strokes live forever and never break. ask any salesman. some even say they fry eggs bettern tha ole lady. good luck and let me think on this a bit
  #3
Old October 11th, 2004, 04:35 PM
The level on the dip stick does not seem to change a noticeable amount but it has only been happening about three weeks. The oil was changed in the spring and I was very careful to make sure the rubber seal was on the oil filter and it seated properly. I see no oil leaking around the filter. Thanks for the reply. These situations make me long for a pre-mix two stoke. I miss the smell of a two stroke!!
  #4
Old October 11th, 2004, 05:46 PM
The boat is on the trailer now. I checked the oil level and it is about 1/2" from the top of the cross hatch marks on the oil stick. I am going to now tilt the engine all the way up and lower the tongue of the trailer to approximate the level of the boat as it floats in the water to try to duplicate the problem. I will post results. Thanks again.Kevin
  #5
Old October 11th, 2004, 06:15 PM
I went out at night with a flashlight and was able to clearly see oil drip from the oil seal at the top of the drive shaft. Has anyone else had this problem on 4 stroke yamahas and how hard is it to replace. I hope the new seal design is better than the old seal. I am not happy with this type of failure on a yamaha. I think the oil seals used on a 4 stroke outboard should almost never fail because that's like pouring used oil directly in the water.Thanks, Kevin
  #6
Old October 15th, 2004, 07:50 PM
rowbards rowbards is offline
The 80-115 had a oil pump problem that the seal was damaged on assembly, some wouldn't show up till engine grew in hours, I have replaced a couple of these and the only indication would be oil dripping from the drive shaft and it doesn't seem to be coming from anywhere under the cowl. The fix would be to remove the powerhead and replace the oil pump. Some of these have been considered for "good will" if you have a dealer take a look and make a call.Hope this helps...Jay
  #7
Old October 27th, 2004, 04:57 AM
motojatu motojatu is offline
Quote:
Originally posted by rowbards: The 80-115 had a oil pump problem that the seal was damaged on assembly, some wouldn't show up till engine grew in hours, I have replaced a couple of these and the only indication would be oil dripping from the drive shaft and it doesn't seem to be coming from anywhere under the cowl. The fix would be to remove the powerhead and replace the oil pump. Some of these have been considered for "good will" if you have a dealer take a look and make a call.Hope this helps...Jay
  #8
Old October 28th, 2004, 04:48 AM
Thanks for all the help and info. The dealer said Yamaha will cover the parts and I will pay about $225.00 labor. Sounds fair to me on a five year old engine.Thanks,Kevin
  #9
Old November 2nd, 2004, 05:13 AM
ebubeck ebubeck is offline
Same problem with a Mercury 90HP 4stroke 2001, powerhead by yamaha, and I'm willing to bet the same oil pump and seals as your yammy. Shame on yamaha.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
40 HP Yamaha 4 Stroke - Fuel Leak rutropa Yamaha & Suzuki Outboards 0 July 19th, 2006 11:26 PM
Fule leak when engine is tilted up FAV453 Johnson & Evinrude Outboards 1 November 1st, 2005 06:56 AM
oil leak from Yamaha 115 HP 4 stroke Bahama Dawg Yamaha & Suzuki Outboards 5 August 28th, 2005 10:32 AM
Fuel leak 50 H.P. Yamaha 4 stroke Makky Honda & Tohatsu/Nissan Outboards 3 October 23rd, 2003 08:51 AM
Oil Leak '99 Yamaha 9.9 hp 4-stroke gherrx Yamaha & Suzuki Outboards 1 June 29th, 2003 12:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
