  #1
Old October 11th, 2004, 12:45 PM
fastkenny fastkenny is offline
Default Yamaha oil injection problem
I have a question with oil injection on my twin 1988 2 stroke 150's. Underway, I got the port engine red alarm light and buzzer indicating that oil level in the main (engine mounted) tank reached the lower level.I shut down immediately, checked the level in the remote (boat) oil tank, saw that it was low but not empty (which I understand would stop automatic transfer to the main). I manually pumped the main tank full (using the engine mounted toggle) and cruised home with the yellow oil light still on. When I return to the boat, I will top off both oil tanks and would expect the yellow light to go out.My question is regarding bleeding the pump on the remote tank. I have the clymer manual and it says to bleed the pump after the bypass switch is used. I'd have to remove the supply line that runs from the pump to the engine, then run the pump to bleed it of air. Where would the air in the line have come from? Do I really need to do this? I'd have to pull a deck panel that is sealed with 5200 to gain access to the pump, so I'd rather not if I can help it. THANKS!
  #2
Old October 11th, 2004, 02:20 PM
bigbrownbuku bigbrownbuku is offline
Master Chief Petty Officer
Default Re: Yamaha oil injection problem
sealing your boat mounted oil bottle below deck isnt recommended. there is a small filter located at the pump on the back of the tank that requires service. if your boat mounted tank didnt run dry you wont have any air in the line to bleed. good luck
  #3
Old October 12th, 2004, 06:22 AM
Thanks!I think I'll install a larger access panel to give me regular access to the pumps
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Yamaha 115 oil injection problem imported_tigger Yamaha & Suzuki Outboards 3 August 5th, 2006 10:41 PM
Yamaha Oil Injection Problem RangerJer Yamaha & Suzuki Outboards 28 September 3rd, 2004 03:06 PM
Yamaha 115 Oil Injection Problem yamaha 115 Yamaha & Suzuki Outboards 6 September 28th, 2003 05:21 PM
YAMAHA 250 Oil Injection Problem freeman-c Yamaha & Suzuki Outboards 2 May 20th, 2003 05:36 PM
yamaha 150 oil injection problem jig Yamaha & Suzuki Outboards 5 May 18th, 2003 09:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
