  #1
Old October 9th, 2004, 09:32 AM
alotto alotto is offline
Default 2001 yamaha 4 stroke carb fuel leak
When I sqeeze the fuel line bulb,fuel runs out of the air intake portion of the carb. Can anyone tell me what causes this problem? The model no. isT50TLRZ
  #2
Old October 9th, 2004, 02:34 PM
rodbolt rodbolt is offline
Default Re: 2001 yamaha 4 stroke carb fuel leak
hello one of your carb inlet needles is leaking. time for repairs. good luck and keep posting
  #3
Old October 9th, 2004, 05:45 PM
Hi Rodbolt, thanx for the reply. I have the Yamaha service manual and its supplement. Could you please be a little more specific so I can refer to the manual. I do appreciate your help- CAPTAIN,THANX, alotto
  #4
Old October 10th, 2004, 12:57 AM
bigbrownbuku bigbrownbuku is offline
Master Chief Petty Officer
each carb has a fuel inlet needle controlled by a float. dirt sometimes gets stuck here preventing the needle from closing. if the engine is running or you are hand priming during this issue fuel will overflow through the atmospheric vents in the carb. this is not a do it yourself job to fix however. without a set of vacuum guages you will not be able to reset the carbs sync. time for a visit to your dealer.
  #5
Old October 10th, 2004, 07:17 AM
Thanx,BenC can the carb be removed from the motor or does the whole boat motor need to be taken for the carb repair. Alotto
  #6
Old October 16th, 2004, 05:04 PM
well, you guys were right about my problem. I removed the 4 carbs and found no 3 carb dirty. Idid the necessary cleaning job and reassembled the carb system and reinstalled it on my Yamaha 50. I restarted the motor and it ran great. You guys and my Yamaha service manual said I would need to balance the vacumn in the individual carbs. Please help me under stand why I didnt have to have this done? THANX ALOTTO
  #7
Old October 17th, 2004, 04:00 AM
cause even a blind squrill can find the occasional acorn. if you did not disturb any throttle plate settings or air/fuel adjustments there is a good chance it will be close on reassembly. good luck and keep posting
  #8
Old October 17th, 2004, 09:16 AM
Quote:
Originally posted by rodbolt: cause even a blind squrill can find the occasional acorn....
heh
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help! Carburetor Fuel Leak - 1989 60HP 2 Carb, 3 Cylinder fuel leak from Jet wgstelz Mercury & Mariner Outboards 1 September 23rd, 2006 07:51 PM
40 HP Yamaha 4 Stroke - Fuel Leak rutropa Yamaha & Suzuki Outboards 0 July 19th, 2006 11:26 PM
2001 4 stroke yamaha ranger 360 Yamaha & Suzuki Outboards 3 March 23rd, 2005 09:49 PM
2001 four stroke 80 yamaha GUOD69 Boat Restoration and Building 0 March 20th, 2004 12:47 PM
Fuel leak 50 H.P. Yamaha 4 stroke Makky Honda & Tohatsu/Nissan Outboards 3 October 23rd, 2003 08:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
